22RE timing at 5,000ft?
I am finally getting around to setting my timing on my '85 4Runner 22RE and just wanted to know if I should leave it at the factory recommended 5 or advance it some due to altitude? I'm in Denver at 5k ft. Also, if I advance it do I need to run premium fuel? Right now it runs well, but rich, as black crap comes out the tail pipe.
Thanks for your help!! |
You can play around with it by advancing the timing until the motor pings, then back it off.
i live in 7200elevation and the motor works better if you speed up the timing a little
also advance it 2 degrees and run it on regular gas and you should be fine
