YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   22re swap help (https://www.yotatech.com/forums/f115/22re-swap-help-194981/)
84toyota4x4extcab Oct 24, 2009 12:46 PM
22re swap help
alright so heres the deal i have an 84 toyota and i blew the 22r motor in it. instead of rebuilding that one i bought an 87 toyota with a 22re and i wanna swap it in only thing is is that the 84 is manual and the 87 is auto so i was wondering if i would have to change the computer in order for the manual to work?
Kiroshu Oct 24, 2009 01:13 PM
theres an individual computer for the auto trans itself. as far as i know you should not have to get a diff 22re computer..... i think....
swampfox Oct 24, 2009 01:35 PM
you could swap intake and exhaust manifolds, and keep it carbureted .you will have to install the fuel pump lobe on the cam for the fuel pump. and there is a difference in the exhaust manifolds.
84toyota4x4extcab Oct 27, 2009 06:04 PM
yea i wanna get out of the carburated tho its not fun in the winter
brownbagg Oct 27, 2009 07:10 PM
if you swap the fuel injection to the 84, you have to use the efi computer, there is one wire that goes to the shifter that need to be splice together for it to start. this wire tells the computer the shifter in park. Its a brown and black wire, i think
84toyota4x4extcab Nov 17, 2009 02:00 PM
thanks for the help guys, i figured out that all i have to do to keep the maual is put a jumper on the neutral switch
91Toyota Nov 17, 2009 02:18 PM
Just swap the tranny and transfercase. That is much easier...unless the 84 is in better condition and you like it better?
But yeah, all you need to do is jump the park switch on the auto wiring harness. (I did it myself once!)
84toyota4x4extcab Nov 18, 2009 11:39 AM
yea the 84 is in imaculate condition compared to the 87 plus the 84 has sas
