22re backfire/popping on deceleration
Old Sep 25, 2008 | 02:50 PM
Steaksauce's Avatar
could use some suggestions on what to look for here.
My 22re has 533miles on it and it is running great in every way so far as i can tell except: it is idling at about 1k rpms (a little hi) and when i decelerate it pops, once in a while loud enough to maybe call a backfire. the heavier the load before decel, the more excessive the popping. Running brand new LCE street headers and 2 1/4 exhaust WITH a new hi flow cat.
I just adjusted the valves and re torqued the head, exhaust man, and checked timing-all seems to be good. i am pretty sure all the vacuum hoses are routed correctly. new plugs, wires, cap/rotor, injectors etc....
i was told that the RE shouldn't backfire at all by the tech at LCengineering. I'm a little worried about burning valves or doing something else to mess up this sweet new long block. its in an '85 sr5 pickup. any ideas appreciated. thanks
Old Sep 25, 2008 | 04:28 PM
slacker's Avatar
I have the same problem ...
most I have been told is a small leak from the exhaust will caust this problem .. but I think that is BUNK .
I believe this is a "rich" running engine , but I just cant figure it out .. I have replaced EVERYTHING .. except the air flow meter .. and still NO change !
one of my issues as well , is I dont have "fuel tank pressure" (the gas cap dosnt whooshhh when I remove it ) some say this is not important , but I know it is .. does yours do this ????
my throttle body shaft is also "loose" .. I can actually move it , changing the values on the TPS ..
dang .. these things are gettin' old ....
Old Sep 25, 2008 | 04:37 PM
ffryno13's Avatar
did you guys lose MPG when you put your 2 1/4 exhaust on. cuz i think iam. but mine runs fine. i am running hi flow cat pace setter header and 40 series flowmaster.
Old Sep 25, 2008 | 05:47 PM
slacker's Avatar
my exhaust stayed stock .. but i'm down about 25% on fuel economy ..
Old Sep 25, 2008 | 05:54 PM
ffryno13's Avatar
down like worse mpg?
Old Sep 25, 2008 | 06:16 PM
ffryno13's Avatar
also check your egr valve there is a hose that goes down and hooks up to the vacuum lines(steel) and that can get clogged full of carbon. just put a lil carb cleaner in there let it set and then push a piece of wire down there to clear it out. that valve actually puts exhaust into your intake at high rpms. idk why but it does, it doesn t really make sense but thats the way it worksif you have any more questions email me.
Old Sep 26, 2008 | 06:26 AM
slacker's Avatar
yep ..
I use to consistantly get 400KM's per tank of fuel .. now only 300
I know it's "overfueling" (backfire/ popping , and black exhaust tip) I just cant figure it out .
in my case , it was originally a burnt valve .. so engine was rebuilt , thinking this would "cure the problem .. it did not . EVERYTHING was either replaced , or cleaned . except air flow meter , and computer . I'm going to try the computer next I guess .
Old Sep 26, 2008 | 10:01 AM
4Crawler's Avatar
Check the dashpot adjustment/operation. That is located below the throttle linkage on the throttle body and it slows the closing of the throttle plate when you let off the gas suddenly:
http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
DP is circled in green:
It has a check valve below it that lets air in fast but lets it out slowly. I like to adjust mine so the throttle linkage depresses the DP plunger about 1/2 of it's travel.
Old Sep 26, 2008 | 11:21 AM
Steaksauce's Avatar
well, my exhaust is all brand new from headers to tailpipe so i don't think there are any leaks there.
my throttle shaft does have a little play, but i am pretty sure it is okay for there to be a little, could be wrong about that tho. seems like a little extra air flow might raise the idle but cause backfire?
As far as the mpg question, i haven't actually checked mine yet, i was getting about 21 before my issues that brought on the rebuilt LB. seems to be okay,but i'll b checking for sure on this tank.
The egr idea sounds promising, but because my vacuum pipes were so clogged when i was re installing them, i just bypassed them and ran hoses until i can find a new set of pipes (any leads on where to get one of those?) and i cleaned out the valve pretty good i think.
hey slacker, did you actually replace your throttle position sensor? i have a feeling my problem is coming from there even though it seemed to test out ok with the meter. those things are Flippin expensive tho!
I am going to try adjusting the throttle dashpot too, but i don't think that's it because it still pops long after the effect of the dash pot has passed, like if i am coasting in 3rd or 2nd down a grade for a long period, it just keeps doing it.
could be something to the airflow meter too, don't really get how it would, have to read up on that one i guess. never boring. just psyched to be rolling in the yoti again.
Old Sep 26, 2008 | 05:10 PM
slacker's Avatar
yep .. I did replace the TPS ..
I checked out 3 of them till I found one with correct values ..
I also replaced the throttle body with one that had "minimal" throttle shaft movement (checked with TPS attached and changing values)
I must admit , I have never even looked at the dash pot on the TB .. I just "assumed" a good TB would have a good dash pot .. I will be sure to check it out ..
Although , I have not replaced my air flow meter .. I have changed the "values" on it as well .. there is a blocked off plug ..Penteonometer(sp) .. where you can adjust .. I drilled , and tried different adjustments over time .. and surprisingly .. absolutly no change ?
I even took my truck to a shop , with a "diagnostic" center .. where they hooked all the sensors up to the machine , to see if all were working .. and ALL checked out "A OK " ..
my truck absolutly purrs like a kitten .. starts on the first crank (every time) , and runs like a champ .. I just am not getting the "best" fuel economy ??
Old Sep 26, 2008 | 08:06 PM
pcmentor's Avatar
I read if the valves are adjusted too tight is the only way to burn a valve. Because it doesn't have time to cool against the seat. You asked about burned valves in the top post.
One thing about the TPS is to do a sweep on an analog multimeter and see if any dropouts occur.
Old Sep 27, 2008 | 04:53 AM
eatmorechicken's Avatar
You might also check your timing chain. Your cam timing could be off due to a stretched chain, etc.
Old Sep 27, 2008 | 06:12 AM
pcmentor's Avatar
I wonder if it may have something to do with the EGR system. Maybe it's malfunctioning. Read as: If it's connected to the exhaust system it may be suspect. Also does the egr connect to only one header tube or to all four?
JNapolitano
Nov 14, 2019 07:46 PM
donovanloj
Aug 16, 2015 10:07 AM
129Creepin
Aug 5, 2015 10:12 PM
PlayAwhile
Jul 20, 2015 11:36 AM
