22re
Well I finally got my injector problem fixed.
I have another problem that I need help with. This is a newley rebuilt engine. it is firing ok but to get it to start I have to hold the throttle wide open and it is missing real bad. My firing order is 1-3-4-2. I set the valves at .007/.009 and set my timing at 5 deg btdc. Checked all of the plugs and am getting good spark to all. Does anyone have any ideas? Thanks James: :bang: |
Is the timing chain set correctly? Is there good fuel pressure at the manifold?
check for vacuum leaks, injector leaks or not firring and the EGR also.
Originally Posted by jhksclemm
(Post 50457313)
Hi guys, I have what sounds like the exact same issue with my 85 22re, also a newer motor!!! just like yours! I have replaced the injectors after replacing all the obvious stuff like plugs wires filters etc... But still have a miss, even after injectors. My miss is very noticeable, but doesn't sound quite as bad as yours. It will idle, but VERY poorly! I want to pull the valve cover this weekend and make dead sure that the motor is timed and ignition is timed.
Have you done that? I feel stupid saying this; but are there any timing marks on the cam, chain or distributor shaft that I could use as a reference. The manual just doesnt cut it!! hahaha. After I replaced the injectors and had no improvements; I began to wonder if the injector wires are on the wrong injectors! Maybe that is our problem. Do you know how to check them? |
(Post 50457313)
Thanks |
