YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   22r heating up (https://www.yotatech.com/forums/f115/22r-heating-up-199581/)
wannagetrdone Dec 21, 2009 02:44 PM
22r heating up
I have an 85 sr5 4x4 ext cab. I recently just swapped a 22re out of an 89 in its place by converting it to carb. This engine has got hot ever since I put it in the truck. I have replaced the thermostat ran it without one replaced the water pump and even flushed the radiator. I dont know where else to look.
Symptoms are as follows.
-temp slowly climbs to normal position
-temp rises slightly above normal then drops back to normal(I think thermostat opening)
-from normal the temp will start to climb slowly til it gets hot
-will not heat up just idling but if i crack the rpms a little(2000) or so it will heat up
I have never let it get over the top part of the line in the normal mark Just wondering what degree this is and how hot can they get before I really hurt it.
wannagetrdone Dec 21, 2009 05:58 PM
Guys any imput would be a big help and much appreciated:bang:
84Horunner Dec 30, 2009 10:20 AM
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Hope this helps.
Travisfab Dec 30, 2009 12:05 PM
replace the radiator
TORTIS Jan 8, 2010 06:22 PM
Did you burp the system?
