22r bolt up
if i have a 22r 4wheel drive. Can i used a 2 wheel drive engine to replace it?
yes it would be a swap |
Yes, the 2 wheel drive engine is the same engine thats in the 4 wheel drive.
cool so it should just fit up to the bellhousing that i have already
yeah it will bolt up. you just need the 2wd oil pan and ( I think) the oil sump.
yeah but cant i put the sump and pan from my engine on the 2 wheel drive
oops. I got mixed up. I misread it. you have the 4wd, and the donor is from the 2wd. Yes, you need the 4wd oil pan and sump. :grouphug:
yeah i have a 2wd donor
Originally Posted by toyota4x4907
(Post 51087831)
