1985 4 runner - 22RE engine - timing mark
Old Oct 16, 2006 | 09:20 AM
Doc279's Avatar
My 1985 4 runner has the 22re engine and I am attempting to check the timing. My problem is that the previous owner or sombody broke the timing
mark plate off of the timing chain cover.
I can tell where the plate used to be as you can see the casting supports.
Could somebody post a close up picture of their timing marks ? I've set my timing by ear and it runs OK but I'd like to know that it's right by the light.
I am guessing where top dead center is - hopefully with a good picture I can mark my cover correctly. If the cover leaked - I'd just change it but it don't - so I'm leaving it alone.
If you have anyway of measuring from the side before taking the picture - That would be helpful. The FSM just shows the timing mark for reference
which won't help me without knowing where TDC is on my cover.
Old Oct 16, 2006 | 09:38 AM
waskillywabbit's Avatar
My apologies Doc for not getting your picture. My memory sucks. I'll work on both.
Old Oct 16, 2006 | 09:54 AM
phorunninduke's Avatar
the timing mark is on the oil pump - it is only a few bolts and you can re use the gasket pretty easily.
TDC is at the 12 o clock position. 12* is about an inch left and 5* is about a quarter left - aproximately
best pic i could
findhttp://toyota.off-road.com/toyota/data/articlestandard/toyota/532005/274576/lcpump.gif
Old Oct 16, 2006 | 10:04 AM
Doc279's Avatar
No problem Wabbit - I don't drive the 85 except for once a month and it escapes me too - until I think about it again.
I didn't realize that the timing mark is on the oil pump housing. I really meant to post a picture of what I'm dealing with before now - like I said - just when I think about it.
The runner is getting hard to start when cold - usually after sitting for a week or two. Once it finally starts - it will start with the turn of the key the rest of the day. The initial start may have the engine turning over for two three minutes before she finally starts. Thoughts ?
Old Oct 16, 2006 | 02:28 PM
Quite a few.... it is an 85 right? I am uploading the FSM for you... it has a large section on hard starting. It will be done in about 20 minutes.
Old Oct 16, 2006 | 03:13 PM
http://duke.worldofchiropractic.com/...tatruckfsm.pdf
let me know when you download it... I don't want up too long.
Old Oct 17, 2006 | 02:25 PM
Doc279's Avatar
Thanks - I got it.
Ichneumon
Sep 27, 2015 04:21 PM
bprice0077
Jun 25, 2015 07:36 AM
Eagle564
Jun 23, 2015 11:29 PM
Old Red 94
Jun 16, 2015 08:32 PM
JaredL
Jun 16, 2015 04:47 PM
