1984 Pickup; Part # Help
Old May 26, 2013 | 09:18 PM
iMrEnigma's Avatar
hey guys, i have a 1984 toyota pickup with a 22r engine. my car wont pass CA smog test because the current headers are not original, and do not have egr vavle and hoses.
so im looking to get the OEM Exhaust manifold and also egr stuff.
could anybody help me with the part numbers for these that way i can order the correct fitting parts. thanks alot
Old May 26, 2013 | 10:01 PM
brianh699's Avatar
Exhaust manifold 17141-35040
EGR valve 25620-35090
EGR vacuum modulator 25690-35010
EGR vacuum modulator bracket 25691-35010
Pipe sub assembly EGR 25601-38010
Sleeve ball EGR pipe 90410-16044
Nut union EGR pipe 90402-22081
Cooler EGR 11181-35020
Gasket for cooler 11182-35010
Hose for EGR vacuum modulator 90910-05147
Stud for EGR valve 2 required 90116-08207
Nut for stud 90179-08146
Bolt for EGR valve 90119-08092
Gasket for EGR inlet 25628-38010
I would check a junkyard these will cost you a fortune from the dealership
Old May 26, 2013 | 10:02 PM
Killgore Trout's Avatar
http://www.toyodiy.com/ for your part number finding, you should try posting in items wanted (you might need more posts first, not sure) a lot of people "de-smog" their trucks and toss the egr equipment. I have all mine taken off, but im saving it in case i need to re smog lol.
Old May 27, 2013 | 10:15 PM
iMrEnigma's Avatar
Aww crap, I didn't expect to need that many parts
Anyways, I wouldn't be going to the dealer either way, I was gonna order them online.
But I may just go to the local junkyard and try to find a truck with these parts. I've tried before and the only pickup I found with the same engine was missing nearly everything, and whatever WAS there was all rusted. Well see how it goes this time.
Thanks, ill use these part # to check photos of the parts I need incase I do manage to find a truck.
Thanks, I might try that as well.
Old May 22, 2014 | 07:38 PM
iMrEnigma's Avatar
Hey guys, so I just started looking for these parts again, and I realized that the exhaust manifold I need, is the one in which the smog pip/egr mounts on top of it. Can anybody link me to somewhere i can purchase that specific model?
Falcon78
Engine Swaps
Jul 1, 2015 05:01 PM
Outsane
Jun 24, 2015 05:52 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
MudnBullets
Jun 16, 2015 07:56 PM
