What other bucket seats fit the 83 and older Toyota pickup truck?
I want to change out the bucket seats in my 82 Toyota pickup truck for something a lot more comfortable and was wondering what other seats will work in the 83 and older models? I think I would prefer vinyl.
Thanks! |
1 Attachment(s)
You can go cheap and get some seats out of a later model pickup with buckets, or just about any junkyard vehicle with a bucket you like. If you have the will, you can make brackets for nearly any seat. I bought these new and they fit rather nicely, but they cost a pretty penny. All depends on your motivation and/or budget.
Attachment 168381 these will fit. |
Originally Posted by magentawave
(Post 52045290)
Thanks! |
I plan to put two front passenger seats out of 94-98 chevy/gmc in my truck. Got the seats just gotta install them.
92-92 civic seats almost bolt right in as do 94-00 integra seats.
And all these seats you mentioned can be easily modified to fit 83 and older Toyota pickups?
can any of these be easily modified to fit in a 1989-1995 4runner? not a fan of the OEM seats, too flat..
Originally Posted by Rollz79
(Post 52045466)
SCToy, did you know what model Corbeau seats those are? I like the looks of them!
Baja reclinable ss or something like that, i can find you a link if you'd like.
I found them on Corbeau's website, but I actually like the Moab seat a bit more. How did you mount yours? Did you use the Corbeau seat brackets or did you use the original seat rails?
My 90's Honda or Acura "Seats Wanted" ad on craigslist for my 82 Toyota truck isn't drawing flies so maybe I should consider other seats too??
I have put a bench seat (not stock), then mazda 6 front seats (electric adjustments in the '82 was awesome, it also made me sit higher in the cab), and more recently some bucket seats i got a few years back on craigslist. It is not too difficult to make anything fit in these. If you can, i would recommend removing the existing brackets if they are nasty (mine were) and welding in some new flat iron, or square tubing.
https://fbcdn-sphotos-g-a.akamaihd.n...76245493_o.jpg |
I don't have welding equipment and I don't know how to use it if I did, so how difficult would it be to use different seats without having to weld anything? I could epoxy whatever is needed to the floor though?
(Post 52167080)
There are lots of good options, doing it the right way will obviously cost more. Took me 2 tries before i felt as though my seats were secure enough. Find a mounting bracket and it should make your life easier. |
I get your point but epoxy is amazingly strong stuff which is why its used widely in aerospace and the boatbuilding industry.
You said to "find mounting brackets" but where do you find them? Thanks |
Mounting brackets are difficult to find, especially ones that will match up flawlessly. As i recall there are other brackets that will fit, maybe it is the Celica or Camry, can't recall. I am sure you can "customize" something to fit.
If you have experience with epoxy in such a manner then go for it, as long as you aren't getting the Napa Special of the week kinda stuff. I am personally just a metal hardware kinda guy. In the first gens you want a low profile seat as well, unless you are quite short like me, they don't have a ton of room to work with. |
