SR5 Gauges Size
I have seen the answer to this before but I cannot find it again. What size gauges are in the SR5 gauge pod? The oil pressure and voltage gauges are what I am looking to change out.
2 1/16" or 52MM gauges will fit in the pod.
Originally Posted by suncomb1
(Post 52157724)
Well I the pod I have has the weird amp gauge and oil pressure so I want to replace the amp gauge with an air/fuel ratio and the only one I have found I like is digital. Not sure what size it is though. I can always get a different oil pressure gauge that is in psi and not kg or whatever it is.
There are all types of gauges availabe both digital and analog. Cyberdyne digital, VDO analog, Autometer both and the list goes on. Check Summit, Jegs, Pep Boys, Ebay, etc. If you look at my album "My Toy" you will see VDO and Spek Gauges in my interior.
