Need some info on factory radios and what years are interchangeable
I have a factory AM/FM radio removed from a 1980 Toyota Pickup 2WD and was wondering if it would fit in my 1982 Toyota Pickup 4x4? I'm going to purchase a new '82-'83 dash piece from ebay since mine is cut for an aftermarket stereo. Planning on making a small tuffy style box in between the seats to mount the stereo in. I'm just not sure if the stereos were different from 79-81 and 82-83. Different is ok as long as the '80 stereo will fit into the factory '82 dash assembly.
I'm almost positive the radios are the same mounting wise. I put a bezel from a 79 into my 82 and the only thing different was the heater controls. I doubt the connectors will work however, IIRC they changed all the connectors in 82
Originally Posted by rowdy235
(Post 52335089)
I have both in the garage, the 1980 center to center on the knobs measures 4 3/4, the 1982 measures 5 1/8. The heater control is separate on the 82 instead of being molded into the dash. I might have an extra 82 radio somewhere if needed.
Originally Posted by 2manytables
(Post 52335137)
I'm looking for a stock radio for a 1982 4x4 SR5 Toyota truck. My son is trying to renovate his dad's truck. Any info or help would be greatly appreciated.
Janet |
If you look at the shafts, maybe you can loosen the nut, and possibly slide them in/out to match the dash plate holes. A lot of radios have that feature for numerous applications.
https://cimg9.ibsrv.net/gimg/www.yot...d4c850e861.jpg
The 1979-1981 trucks used a Fujitsu-Ten radio with a narrower shaft spacing. The 1982-3 trucks used a Matsu˟˟˟˟a (Panasonic) radio with a wider shaft spacing as well as a wider case. They are not really inter-changeable and wont fit quite right when mounting on the dash frame or around the plastic bezel. The 1982-83 radio seem to harder to find. |
Thanks for the reply and the info. Yes I am having a hard time finding the radio but I'm not going to give up it is for my son. I appreciate you answering back.
Janet |
This is the radio you need for the '82. It is the Matsu˟˟˟˟a 86120-89118. Apparently two were sold on ebay recently.https://cimg4.ibsrv.net/gimg/www.yot...5d69d90ec0.jpg
https://cimg7.ibsrv.net/gimg/www.yot...224d4b63a3.jpg |
Thank you. Day late and a dollar short. All is good it will happen.
