my clutch blew up and im on a hill in reverse can i take tranny off in reverse?
im on a hill and need to know if i can take the tranny off in reverse cause my clutch blew up so i cant put it in neutral any ideas???
there nothing gonna keep the truck from rolling down the hill lol ,, cant u just put it in neutral with out the clutch
with the engine off you should be able to shift into nuetral
i cant its locked in reverse its resting in the gear
have someone pull you forward a little. Its probly not the best idea to pull your tranny out on hill. Get your truck to a more level spot and while they start to pull slip it in neutral.
ok cool should i get a performance clutch?? or just oem?? i wheel a lot what do u recomend and what brand
the stock clutch was not ment to hold tires over 31's Marlin has some good clutches. Do a search its been covered before.
a lot of people recommend the stock Aisin or the 1600 lb kit from Marlin.
pulling a transmission on a hill would be a PITA. big enough pain in a garage. make sure to secure the truck--block it. |
I threw a 2100lbs marlin clutch in mine.. I have nothing else to replace it to except stock.
Marlin has their 1200LB HD clutch on sale right now for 152 bones.
