Lexan Windshield
Hey guys, I'm wondering if there are any companies who make a lexan windshield for a first gen? The windshield frame on my '83 is mangled around the cage and I need something to go in place of the glass that was gone a couple tumbles ago. :hillbill:
Thanks! |
you don't want lexan.
You're probably thinking "lexan's awesome because it won't shatter like glass and I won't have to replace it ever again" Think again: 1) it scratches VERY easiliy, it'll become extremely cloudy even after offroading it a few times just from dust and small rocks. even using your wipers to get mud off the windshield 2) it expands and contracts much more than glass, making it very hard to seal and make waterproof 3) installation's a pain, most places won't do it because it'll crack after installation from heat expansion/contractions and they don't want to be liable 4) They're illegal for on-road use because if you ever get in an accident that requires the use of the windshield as an escape, a fireman's axe will just bounce off making it much more difficult to extract you from the vehicle. 5) its very expensive to get a molded windshield made of lexan. Even the non-molded ones are expensive. 6) the cheaper lexan will fade and turn yellow after awhile due to UV exposure. The UV resistant stuff is much better at staying clear, but will eventually yellow. I have considered lexan as weight reducing options for my racecar and have done a lot of research and calling around about the pro's and con's. Its just not worth it, especially for offroading. Even on-track competition cars end up replacing the lexan frequently because it clouds up so easily. They're also riveted on in most cases and aren't waterproof. I would just recommend getting a replacement glass windshield. |
You can go to Home depot and pick up sheets of lexan and cut them to shape yourself. This is what we do with my Race cars. I picked up a sheet for around $75 and had enough left over for quarter windows in my 91 MR2. Since you have rolled your truck, i am assuming you don't care about the body so it would be best to rivet it on.
if they don't have Lexan ("Lexan" is a brand name) make sure you get Polycarbonate. They also sell acrylic plastic, and that crap will shatter. You can't cut it like you can lexan, and it will not flex into a windshield shape. |
$75, really? o_O
what thickness and how big are the sheets? and yeah, if you do end up doing it, riveting is the best way to go. Just don't press the rivets down all the way or else you'll split the lexan. |
they are pretty thin, i can't remember the thickness i used. The sheets are 36x72
look at a product called Makrolan: http://www.makrolon.com/BMS/DB-RSC/M...nsf/id/home_en
I got lucky and scored a sheet off craigslist. the stuff is awesome. they make a lot of headlight lenses out of it. Made a back window out of it for my '81. did this with a piece of scrap: http://i119.photobucket.com/albums/o...krolonflex.jpg |
Thanks guys.
I was afraid of the smearing/scratching side effect. |
| All times are GMT -8. The time now is 03:58 PM. |
