L43 backup switch removal
Hi Guys, new to the forum and to mini trucks.
I need to put a new backup switch into my L43 tranny, do i need to drain the fluid or can i just remove and install new one? thanks. |
Well is the switch above or below the fill plug??
Not sure with that trans but most you can just change the switch Unless the gear oil needs changed |
low on the rear right corner ... hence the question. I suspected the fluid will need to be changed out but thought i would ask... I guess i should change the fluid anyway. the truck has 122,000 km on it, one owner. he seemed to look after it but who knows for sure.
