#201
#202
heres my 80
poser pics not me the truck at grey rock orv
another at grey rock
the flatbed i built
anoter on grey rocks trails
next to do is some racing seatstie in the rollcage to the frame ,ladder bar to stop the axle wrap,change the rear springs and make some longer shackles to loose the blocks in the rear,then rip it all out for 4link in the spring,change front bumper and put the 8274 warn in it
the flatbed i built
#204
Hi, I'm new here, just bought this '79.
It is rough as hell....
As you can see it needs alot of work, not to mention it needs some off road tires badly.
One good thing is the guy I bought it from is a mechanic and he just installed a newly rebuilt 22R.
#207
Right now my plans are:
Fix ignition, there is some funky wiring going on and doesnt require a key to start.
Fix lighting, again funky wiring lights wired straight to battery, turn signals don't work.
Fix back brakes and parking brake, they are unhooked.
Fix seal at top of windshield, has a small leak.
Find some 31" tires, don't know if the gearing is good enough for bigger.
Find a decent bed ( that will be really hard), or fabricate a flatbed.
Install new shocks.
Check my front supsension/driveline, there is a bad vibration at 50 mph or higher.
Other than that she just needs alot of loving.
Install new shocks.
#208
Tires: 31's are a good choice to get you going...you can usually find a good set of used ones cheap
Leaky windshield--I did a new winshield and seal a few months after I bought mine due to the 'small leak'--ripped out the carpet to find this after I don't how long it was leaking
welding in some new metal for floors after the first of the year..
#209
#211
#215
Lots of nice rigs in this thread. I like what you have done Rockalot. Got any more pic from differant angles of your exo and sliders?
#216
#218
I don't think mine has as much rust. I need to get a bed for this thing too. The guy I bought it from was the original owner and fabricated this utility bed to use with his welding business. The bed probably weighs 8X more than a stock bed, so breaking 45mph uphill is a battle.
#219
That is nice and clean. Always like that factory paint job, don't see it much any more Hope your 5 Speed conversion goes easy. DeathCougar's post pretty much gave you all the info you needed..
Awesome truck. I checked out the build on both websites. Probably one of the best equipped 1st Gen's out there. It gave me some ideas for my '81
