Head light issues, light issues
I seached and did not find this problem. new to toyota. new to forum. I have a couple questions.
1. Are the lighting system on these trucks always problems? 2. I have one head light that is dimmer than the other.( yes i replaced the bulb and end connector.) Ideas? 3. Is there a best practice or good idea to replace the wiring to the back lights. ( Want to add some Back up lights) Old wires look ripe for being torn off by anything. |
the headlights are problematic. Sometimes acid from the battery on the passenger side will corrode the headlight wiring.
I bypassed most of my headlight wiring with a PIAA H4 wiring kit I got dirt cheap. 4Crawler makes a similar kit that helps a lot |
| All times are GMT -8. The time now is 12:15 AM. |
