grind/rubbing noise in front when in 4wd
i got the truck going and when i have it in 4wd it will make a grinding rubbing noise, it almost sounds like its coming from the passenger front tire area but im not sure. could there be not enough grease some where or somthing?.....any ideas?
Did you have the rotors off? There is a rubber bearing seal on the back of rotors that can get bent and cause it to rub/cut into the hub shaft. I have never actually heard of one making a loud noise tho...
i havent my self, but i was thinking of something to do with the brakes, but like i posted....it only does it in 4wd, so im thinking its something with the hub. i dont know if something normal since theyre lockd or what
nobody knows? i also thought about the wheel bearing but the wheel doesnt really have any slop in it
Does the sound change when your turn? Does it make noise if you unlock the passegener side hub?
no, it was doing it when i was going straight. it would make the noise and pull to that side at the same time. it sucks cause im kind of limited to tools and everything as i just moved out. im hopeing to take it to my dads this weeknd and take it apart
Almost sounds like a brake dragging. That might explain why it pulls. Does the sound change if you put on the brakes? Might be a problem with your locker and just the right side is locked. Try unlocking the right hub and locking the left hub and see if the left one is working.
see i first thought the brakes to but it only does it in 4wd but ill try the hubs tomorrow
Good luck!!!!!!!!!!!! It's not much fun pulling the front third if you need to check your locker.
