YotaTech Forums
-   Pre 84 Trucks (https://www.yotatech.com/forums/f114/)
-   -   Fuel Pump issue (https://www.yotatech.com/forums/f114/fuel-pump-issue-154510/)
swiggyjr Sep 13, 2008 04:18 PM
Fuel Pump issue
Okay i have a 20r motor and hooked up a mechanical fuel pump worked great but when i needed to hook up the water outlet on the engine it ran into to the fuel pump anyway i took it off and proceeded to hook up an electric fuel pump. Here is the prob i had a 2.5-4 psi pump and it would prime but wouldn't put any fuel into the bowl of carb NO FUEL so i thought maybe there wasnt enough pressure so i bought a 5.5-9 psi ran for a minute and now nothing truck has 1/2 tank of fuel, ran great with mech and now nothing keep in mind this is an 81 truck with the return supply to and from the tank any ideas????
kdo58 Sep 13, 2008 06:32 PM
I have a 81 with a 20r and it has a electric fuel pump, so if you you take the fuel line of the carb and turn ob the fuel pump and gas comes outm then i would guess you have a carb issue. I have a wber 38 on mine, got rid of the stock carb and all the extra vacume lines.
Scooby098 Sep 15, 2008 09:49 PM
is your gas cap on tight it needs a seal sometimes , also can check to see if your fuel fliters are clogged I went out and bought a new electric pump thinking mine was dead but there was just a hidden fuel fiter by the tank.,
