front wheel stud replacement........im stuck please help
2 Attachment(s)
I got my 2" wheel spacers in but i cant put the front on till i replace a few of the studs. After i started i realized what a large project it would be. i got this far and the book isnt very helpful please help.
Got to pull off the wheel hubs. Wheel studs are press fit through rotor and wheel hub.
www.ncttora.com/fsm :wabbit2: |
How do I get the wheel hub off? Are there any special tools?
Follow link and download the fsm and read
OR Search It's covered umpteen dozen places online how to break down a solid front axle. http://www.4x4wire.com/toyota/mainte...ont_end/rotor/ :wabbit2: |
thanks. i needed to buy a 54mm socket to get the giant nuts off then the wheel hub came off.
Did you get it figured out?
:wabbit2: |
Yeah I replaced the bad studs, regreased, and reassembled everything. Must have put the manual hub on wrong cause when it's turned in the unlock position it's still locked.
