warmonger88 |
01-24-2016 02:08 PM |
83 4x4 loses low beams entirely, has hi beams
I have an issue that developed after i did a gm one wire install. i was driving my truck with the low beams on and they just shut off. I still have the high beams that function just fine. I have a Hella H4 upgrade and the fuse holder on the H4 harness was a ceramic lined fuse holder, until the ceramic crumbled and power arced across the terminal around the fuse..... I have changed the fuse holder, added a giant blade fuse inline from the alternator to stop it from even getting as far as my headlight harness again. I have changed to fresh H4 bulbs and well as checked the two relays on the headlight harness AND the two on the truck's cab harness, all checking out fine. Both interior fuses for headlights are fine also. Is there anything anyone else can think to check out? I'm stumped.
