80 4X4 Next mystery 4.88 Rear Diff (SOLVED FOR NOW) THANKS
Now I need a new rear diff and I would like to get a complete 3rd member.
1 Mystery ONE.. I counted my drive line and came up with 4.8 revolutions.. I do not see a 4.88 ever being used in 79-83. Am I to assume some one stuck in a 4.88??? I am turning 3500 rpm at 60 with 30 inch tires. Sound right???? 2 Mystery TWO .. Does anyone know of anyone who sells toyota 3rd members with 4.88's ??? 3 Mystery THREE Is it possible to get a clutch type posi traction for this rig?? thanks mark |
I have an '82 that has OEM 4:88 gears. not sure if they are stock but they are OEM.
Yeah, in my '83 with stock gears, 30" tires, I'm probably....wait, what gear? That's very important. At 60mph, I'm not even at 3500 in 4th gear, so yeah, you definitely don't have 4:10's.
so did you count the front Diff spin too? remember 4x4 implies matching numbers front & rear are needed. The count the rotations method is very subjective
do some math with this gear calculator: http://www.csgnetwork.com/gearratcalc.html using your numbers and that link shows that you have 5.208333333333333 which is more than likely 5.29's --lucky dog you-- you are golden for a set of 35's edit: with 30" tires, @ 60 mph if you had 4.88's you would be turning about 3250rpm's Mystery #2 solved: just about every gear house sells 4.88s for a 8" 4 cyl toy diff. my googling crystal ball was cracked so I used my memory: trail-gear, randy's ring & pinion, marlin crawler, All-pro, Yukon gear, Motive gear but you seem to need 5.29's |
BUT, if you're keeping 30x9.50's on there, man, you really don't want 5.29's. Sell em and buy yourself either some stock gears, or maybe 4.56's. 30x9.50's are darn close to stock, so you don't even need to anything over 4.10's with them, although a slightly lower gear ratio would help with power a bit.
If, as I'm assuming, you're going for a stock-ish truck, 5.29's are just crazy. 5th gear, 3500 at 60 is not ideal...not if you ever plan on driving 70.. |
Get some 33's and forget about it.
Count the teeth on the ring and pinion gears to make sure you get the correct ratio. spinning the driveshaft and watching the tire isn't always very accurate.
wow according to this i have 4.88 also. in my 82. i have a 4 speed and turn 3000 with 33's at 60mph
i have a question? i have a 80 2wd would a 80 4x4 3rd member bolt in? and if so would it be a different gear ratio?? id like to get a stronger rear end cuz i am putting bigger tires on my lil toyota
Remember I still have the 4 speed in here so every thing is base on 4th gear. The tires are 30x9.5x15s, I do not really want the truck any taller than it already is. I never go much faster than 55 as we have no freeways around here. I figure once I get the 5 speed installed that will drop my RPMs down to 3000 at 55 in 5th gear..The speed calculator does not say if its set up for forth or fifth gear so i doubt its accuracy. What if I spin my wheel 20 time and count the drive line turns..Would that not be pretty accurate??
Also the only limited slip unit I can find Is a Detroit but they want 400 buck for it above and beyond the third member I still need. Are there any factory toyota diffs from newer trucks that might work in the 80? DaveZ said he would ship me a rebuilt 4.88 third member for $349 exchange which I thought was really fair. But I still want a limited slip for snow mark |
Originally Posted by 69800
(Post 51287427)
mark Davez' price is good and after dealing with him on some orders I feel you will get great service.
(Post 51287427)
http://www.grimmjeeper.com/gears.html and if these don't work for you google gear calculator and yep I have the gear ratios for both:D spinning a driveshaft is very inaccurate to determine gear ratios...it only takes 30-45 minutes to pull a third...pull yours count the ring gear teeth and divide by the pinion teeth to get a real count |
I meaured the tires .....29 inches tall...
I counted the driveline with 20 tire rotation 48 and 1/2 revolutions = 4.88 gears in the diff. speed test coming after breakfast I have to find my l-43 gear ratios.. I saw them somewhere |
Spin your tire two times, twenty times wow that is a lot of counting. Make sure you mark your tire and your driveshaft. If your driveshaft rotates almost five turns then you most likely have 4.88's.
edit: Better yet just do what ocdropzone said and remove your rear differential and count and divide and there won't be any more guessing. |
Im getting ready to put in a 5 speed and trying not to tear it down twice. But I may have to
Oh...just wait! I agree with trying not to do things twice but...with a truck this old, believe me, you'll be tearing multiple things down multiple times! Just wait! The fun is only beginning.
My L52, with 30x9.50's, I'm at about 3000 rpms in 5th gear at somewhere between 65-70mph, I think. |
(Post 51287690)
http://www.marlincrawler.com/tech/tr...ar-ratio-chart |
idk if this helps but i can cruise at about 65/70 mph at im at like 2800 - 3100 in my lil toyota??? idk if that helps but thats how that is but im lifting mine and putting bigger tires so it will change.
I plugged every thing into the grimmjeeper.com calculator and it says I have 5.29 rear diff gears. Where you imput the transfer case ratio I tried 2.28 but the numbers were way off, so I used defaut toyota selection at the bottom of the list and it came up with 5.29s. I do not know what they are using for default toyota transfer case ratio however???
I BELLIIEEVVVEEE you should go ahead and buy a 5.29 gear set for the rear....
then take your rear third..and your front third...ship them to my address and i'll ship you my stock 4.10's in my '80 toyota :) totally kidding...you'd have to be a dang fool to do a trade like that just get ya some 33's man..like a set of 33.10.50's!..the height wont be much different..and you'll be close to 3000rpms on the highway |
