79-83 Wheelbase Measurements LB vs. SB
Can someone take some measurements? I was looking at a frame in junk yard with no bed and no axles... Hard to tell what it is ...
Also, How long is the bed itself? Long Bed and Short Bed? Thanks from a Newbie! :hillbill: |
well IIRC the short bed inside is a little over 6', and the long bed a little under/over 8'
Frame Dimensions: 79-83
http://members.myecom.net/kmcwilli/i...dimensions.jpg http://tellico.off-road.com/wwwthrea...-untitled1.jpg http://tellico.off-road.com/wwwthrea...-untitled2.jpg http://tellico.off-road.com/wwwthrea...-untitled3.jpg Frame Dimensions: 85 Thanks Budbuilt http://www.yankeetoys.org/Documents/85Frame.gif http://www.yankeetoys.org/budbuilt/i...85%20frame.jpg stole this from http://www.pirate4x4.com/forum/showthread.php?t=459180 |
those links for the 79-83 don't work for me.
ditto
Shortbox = 102"
Longbox = 112" Those aren't exact but close. |
From http://www.4x4wire.com/toyota/faq/
" two configurations offered were a shortbed with a 103" wheelbase and a longbed with a 109" wheelbase" |
Thanks.. .I'm going to the junkyard today to measure the frame... the axles were gone so I'm not sure where to measure from.... we'll se what I can come up with.....
man none of the links work.
(test) http://bbs.off-road.com/wwwthreads_u...-untitled1.jpg http://bbs.off-road.com/wwwthreads_u...-untitled2.jpg |
So I went to the yard Thursday. There was only one 1st Gen 4X4.. It was a shortbed too ... But it took a hard hit in the pass front fender.... tweaked the frame... but there was no rust!!!
Ther were about six 2wd's... some long some short beds... no rust in the beds but they all had some sort of damage.... The simplest way to tell long Vs. short seems to be the distance between the two mounts at the back of the cab and the bed.. They're either about 5" apart or 11" ... quickest way to ID that I can tell .. . |
