20r intake setup w/22r head and block... different - YotaTech Forums
Pre 84 Trucks 1st gen pickups
LinkBack Thread Tools Search this Thread
Old 05-09-2011, 06:57 PM   #1
80wheelerjake's Avatar
Ok so i have this very unusual setup. Its a 1980 4x4 pickup with all the cali specs. those stink by the way.
anyways this truck has a 22r head and block but that is all the 22r-ness that this baby has. the previous owner set it up this way.
the intake manifold is held to the head via a home made 1/8 in thick adapter plate and it is really wierd.
it has the layout of the 22r intake holes, minus the ports that the 20r intake doesnts have, it has a 20r manifold gasket on one side and a 22r gasket on the other.
i works great but i dont like it, i cant get a webber to tune to it because of the intake vacuum leaks due to the adapter. so here is the question i have...
with all of the 20r wiring and set up and stuff, can i just put a regular 22r manifold and carb on it/ or am i going to have to change some stuff?
80wheelerjake is offline   Reply With Quote
Old 05-10-2011, 09:08 PM   #2
peow130's Avatar
1/8th inch thick? how does that work?
put a 22r intake and carb on it..
peow130 is offline   Reply With Quote
Old 05-11-2011, 03:46 AM   #3
xxxtreme22r's Avatar
find a 20r head port and polish it, slap that on. 20r/22r hybrid FTW. Perfect time to do it.
xxxtreme22r is offline   Reply With Quote
Old 05-11-2011, 03:32 PM   #4
yeah all that plate is, is just an adapter to cover mix matched holes and to preserve the gaskets. otherwise i would be having chunks o gasket in my head.
Old 05-11-2011, 03:33 PM   #5
now if i do that, is that all i need to do? i heard there was some machining involved and some work with the cams.
20R Break in- Really High Oil Pressure calderp Engine Swaps 2 08-16-2016 05:15 PM
HiGH oil pressure breaking in 20R calderp Pre 84 Trucks 8 07-27-2015 09:58 AM
Alternator swap, keeping it all Toyota. 80Truck Pre 84 Trucks 8 07-24-2015 03:12 PM
88 3vze: need diameter and pitch of threaded holes on the side of the head whereAreMyPants 86-95 Trucks & 4Runners 2 07-22-2015 03:32 AM
22r leaking 87blyota 86-95 Trucks & 4Runners 3 07-10-2015 04:31 AM
Tags
1987, 1987toyota, 20r, 20r22r, 22r, adapter, gasket, head, hours, intake, labor, manifold, replace, toyota, truck, vacume
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
