1982 Shifter question
I have a 1982 4x4 SR5. I just got done replacing my shifter bushings as my shifting was getting difficult. I used the Marlin brand. Anyway after installing it I am still having issues. I am trying to find a picture of the end of the shifter itself. Mine seems to be worn but I am very new to Toyotas so I might be mistaken. I have tried to find sites with diagrams but no luck. Any help would be greatly appreciated. Miss driving my truck big time...Thanks Kyle
Should look something like this:
http://www.4crawler.com/4x4/ForSale/...r/p1030469.jpg Under the plastic end cap is a spherical end. |
Thanks for the quick reply. I wasnt thinking too much and forgot I had my friends camera. Here are pics of my shifter showing the grooves on both sides. Is that how they should look ? Thanks
http://i13.photobucket.com/albums/a2...p/DSC04900.jpg http://i13.photobucket.com/albums/a2...p/DSC04899.jpg |
Grooves should be a single width and square sides typically, like a dado groove in a piece of wood.
WOW...mine started as a single width hahaha. I just didnt know how the shifter should look in relation with the pins right about the shifter seat bushing. I am trying to learn all of this but my service booklet doesnt show much. Now I just have to locate a good used shifter..a new challenge..LOL Thanks for your help. I appreciate it
BTW. I grew up in the SF Bay Area...Hayward |
I have an extra shifter or two if you can't find one locally. Think I paid about $25 each for them.
Ya if you have one that would be great. I cant seem to find much local. My zip code is 95662 for shipping. I can paypal you the money..Thanks Kyle
Here are two that I have:
http://www.4crawler.com/Photos/104_pana/p1040044.jpg Looks like the earlier style (upper/right one) has slightly worn grooves, not as bad as yours, the later model style (lower/left one) looks pristine: http://www.4crawler.com/Photos/104_pana/p1040045.jpg Postage would run $6.00 plus $25.00 for the shifter, Paypal address is "r.c.brown@ieee.org". |
can you describe your shifting 'issues' a little better?
i can pretty much 'row' the gear shift around, i wonder if this is the cause... Al |
My biggest issue was going into reverse. It just would grind. The few days I had to drive it to work I started the engine with it already in reverse. The other gears werent too bad to get into. Downshifting from 3rd to 2nd wasnt too good either. I did change the shifter bushings to the Marlin brand. Mine were wore out but not too bad. I never checked the shifter end until after I installed everything to find out it was still grinding...good thing for cameras and the forums Kyle
grinding into reverse sounds more like a clutch problem to me.....
Originally Posted by rowdy235
(Post 50866219)
FYI all Toyota pickup's that ive driven cant be rolling when you put it into reverse or it will just grind. |
Originally Posted by Island_Yota
(Post 50866638)
Or worn out syncro's in the tranny itself.
FYI all Toyota pickup's that ive driven cant be rolling when you put it into reverse or it will just grind. [Once again sorry If I have misunderstood] |
(Post 50866638)
FYI all Toyota pickup's that ive driven cant be rolling when you put it into reverse or it will just grind. that is why you need to stop moving for a few seconds and have the revs down before you put it into gear. it is my understanding that there is no point of failure in reverse other than the gears not lining up to engage because of the lack of syncros.... where double clutching may be needed. any real issues would be clutch related. Al |
Originally Posted by my65rhd
(Post 50866190)
Al |
Actually per my haynes manual GL-4 is recommended for the tranny.
Every Toyota I've ever driven would grind at least a little going into reverse.
While we are talking about manual transmissions on the L52, My shifter is loose and sometimes spins around. I was reading something about changing the shifter bushings. Is this something that can be done without removing the transmission? Where can I get new bushings? Is changing the bushings a difficult task? Thanks
You can do it from the front seat:
- http://www.off-road.com/trucks4x4/Te...tegoryId=11289 New bushings from Toyota or upgraded ones from Marlin: - http://www.marlincrawler.com/htm/tra...rans_parts.htm Worthwhile pulling the shifter out to see what the base looks like. If the bushings are gone, that may be your problem, but if the side pins in the base or the grooves are worn out, then the new bushings may not totally fix the problem. |
My 83' has an EXTREME amount of play. It goes into all the gears just fine, but the stick itself is super loose. The previous owner told me the two bushings were bad or gone. He told me he could only get the bushings from a dealer. He also told me he had ordered them but I was thinking about just changing them myself.
Would I need to drop the trany to do it or do they just slide on? |
