YotaTech Forums
-   Axles - Suspensions - Tires - Wheels (https://www.yotatech.com/forums/f11/)
-   -   FS[GreatLakes]: Marlin Crawler 27 spline triple drilled pinion flange (https://www.yotatech.com/forums/f11/marlin-crawler-27-spline-triple-drilled-pinion-flange-316021/)
CheeseRind Aug 29, 2022 11:50 AM
Barely used Marlin Crawler 27 spline pinion flange. Installed it in January of this year and only put about 5k miles on it before doing a regear with a 29 spline pinion, so I don’t need it anymore.
Given the super light miles on this thing it’s in really nice shape, and the seal mating surface is spotless. The ring visible in the photos is from where it was just starting to get polished, machine surface is still visible. Dust shield is in great shape but can be knocked off if you don’t want to run it.
$25 shipped to your door. Otherwise it’s just acting as a paperweight for now. Reply here or text me, eight one zero, 2 4 O, I 3 7 9.
Fits the most common differential bolt patterns:
  • 1963-8/69 FJ40, 1979-83 Hilux, 64 x 56 x 8mm
  • 1984+ Pickup, 60 x 60 x 10mm (non-CV)
  • 1986-87 Turbo, 1988+ V6, FJ60, 66 x 66 x 11mm
https://cimg4.ibsrv.net/gimg/www.yot...a38c9b5d1.jpeg
https://cimg7.ibsrv.net/gimg/www.yot...de50d370e.jpeg
https://cimg1.ibsrv.net/gimg/www.yot...fba253faa.jpeg
https://cimg4.ibsrv.net/gimg/www.yot...8ccb416fb.jpeg
