87 4Runner SR5 4x4 A/T $9500 OBO
https://cimg5.ibsrv.net/gimg/www.yot...c34128a111.jpg
87 4Runner SR5 I was building for my son when he turned 16. Well, decided he didn’t want it. Odometer shows 262K, but engine and transmission were rebuilt at 257591, so basically under 5K on them. Nothing from the old engine was carried over to the new one. About the only thing still original under the hood is the charcoal canister, wiper motor and fuse/relay box. A/C system was also completely rebuilt with new components at this time. Only thing that doesn’t work is the cruise control, the rear window defroster and the auto slide on passenger seat. Passenger front fender was replaced with a factory fender I found out in AZ because original had some damage when I bought the truck. And of course, about 2 weeks after I put it on, a tree branch fall on it and dents it. A/T, PW, PL, Power Mirrors, Power Antenna, Sunroof, Tilt Wheel I’ve attached 1 photo, but here’s a link to over 100 more https://photos.app.goo.gl/uaRavqjKcnEbYRVd8 Listed below is what’s been done to vehicle during/since the rebuild. Engine .040” over Egnbldr StreetRV Head (1 mm oversized valves) Egnbldr 268C camshaft (268 degree / .425” lift) Fuel system converted to manual FPR 82 Supra AFM w/LCE K&N kit Throttle body bored and upper intake plenum bored to match Battery Swap Aluminum Radiator w/electric fan Pacesetter Header with full 2.5” exhaust High Output Coil Oside Tiger 4 hole high impedance injectors A pillar gauge pod with Volt, Air/Fuel and Trans temp gauge. Trans temp gauge is bad due to me connecting a wrong wire. New factory power window switches New power window motors, regulators and window track rubbers both front doors New rear window power motor New bushings in the shifter New gas tank, fuel pump and sending unit New steering box New PS pump New tie rod/drag link ends and idler arm Have new upper & lower ball joints, not installed Upgraded to dual diaphragm brake booster and 1” master cylinder Upgraded to 88 V6 4Runner 4 piston calipers Upgraded to slotted cross drilled front rotors New front wheel bearings New brake lines, only factory hardlines not replaced New rear drums New wheel cylinders All new brake hardware New Load Sensing Proportioning Valve All LED lights New rear pinion seal and Yukon Gear yoke New front fender inner liners New wheels and tires with maybe 50-100 miles on them Brand new spare Add-a-leaf leveling kit The following have somewhere in the 8-10K miles on them Front CV axles Pro Comp shocks New urethane bushings in rear leaf springs |
| All times are GMT -8. The time now is 05:09 PM. |
