stock diesel full engine, wiring, bell housing, full swap Mansfield, OH
You shouldn't have a problem. Where I live you don't have to smog a diesel unless its new. The test is nowhere near as stringent like gas. I'm an 81 there shouldn't be any smog for a diesel
That really is a good deal. I have been pricing replacements for a customers 22re and they are about the same cost. I remember when we could find a good 22re for a few hundred dollars. Getting harder to come by I reckon. GLWS. I'd like to have it myself.
#27
If it's still available at the end of October ill buy it from ya. I'm in cali, so I may be able to drive out there or get it shipped if that works for you.
#33
Alright. I have decided to drop the price down to $500 for the diesel engine and everything that goes with it. I need to move this piece of history. Shoot me an offer.
#34
That really is an incredible price.
You should list the engine number/name....its either a 2L,3L or 5L(totally guessing here). probably a 2L(guessing). IIRC you can source a 3L head fro the 2L to give it a few more ponies.
That may help folks doing searches.
also, you refer to a fuel pump, are you talking about the injection pump? Those hang off the side of the engine, and do not use an intank pump. Some diesels will use a lift pump in the tank, helps the injector pump in some instances. That would explain why you don't have one in your tank now.
Good Luck with the sale.
#37
http://www.toyotadiesel.com
Member since 2007
KX250Erick
GLWS
I'd glady trade you $750 worth of parts - I have 200+ parts and have wanted a diesel forever but never found a complete swap which was cheap enough
Does this come with the diesel gas tank
Member since 2007
KX250Erick
GLWS
#38
RBX; it is a 2 liter gas engine in the truck now. When the diesel engine was in the truck the fuel pump was on the frame externally. I chose an external gas fuel pump to replace it as at the time I was hoping to mod the truck and make it my daily driver.
Erick561; yes it does come with the diesel gas tank. I am not sure if I mentioned that in my posting or not. I thought I did, but yes it does come with all the other pieces for this engine swap.
