for sale 96 3.4 engine 100k mi. in nc
1996 3.4 engine only. 900.obo
monroe nc |
Can you send me some details on the engine? Is it a rebuild, any problems at all, and any other info you can give me?
the engine is from a 96 T100 with 100k mi.. it looks like it was in a head on, drivers side motor mount is bent, and the bracket mount on the intake is partially broken off, but repairable, if needed, i did not need this bracket on my swap. the intake is usable. the harness is cut(salvage yard) the timing belt cover, and the fan mount bracket is gone. i was going to use this engine for my swap, did'nt find a harness so i ended up going with a 2000 4runner engine, trans, harness and ecu from the same car. i swapped the oil pan,sump and dipstick from my 4runner engine, i have a oil pan from a 3.0 ( same as T100)for a swap. this engine is very clean inside and out, no oil leaks etc. i would change the timing belt water pump before install.
Any ideas on crating and shipping costs to 39180
will check and let you know.
you can check out these guys. you know where to ship it to,residence, business or terminal. i can crate, and deliver in their truck from a business with a forklift in Monroe N.C. http://www.uship.com/
new lower price
is the bracket on the intake manifold the throttle cable bracket? i need a throttle cable bracket if you can part one out, even if it's partially broken.
i'll have to check, it's been a while since i've looked at it.
still have.
Hey is this still available,if so what's the new price??? I'm in Greensboro so I'm not that far from ya...thanks
still have ,PM sent.
Do you still have this engine?
yes still have the engine.
bump.
still for sale.
uhhh bump.
Do you still have this engine can you ship it? I live in oregon
yes i do.
let me find the shipper i found that has reasonable rates. i will need more info to get a quote so i will pm you when i find it. it will be more expensive to have it shipped to a house rather than a business with a forklift, or you pick it up at a trucking terminal. |
Good deal on this motor, found one on craigslist near me with 200K on it for $2,000.
Good luck with sale! |
| All times are GMT -8. The time now is 04:28 PM. |
