22RE Garage Sale
I have a tub full of stock 22RE parts leftover from my engine swap. Engine mount brackets, mounts, starter etc, CLEAN valvecover.
I also have this stuff someone can make use of. Toyota OEM full upper/lower gasket kit, seals etc.. Sold Sold22RE Ecu computer guaranteed working $75 SoldThrottle Body(complete with working TPS) $40 Sold Intake Manifold with working sensors $100 Pickup full stock exhaust.. Sold 22re power steering pump.. Sold Cold start injector(reconditioned with zero miles since cleaning) $25 Sold Flamethrower injector set and adapter plugs(brand new) $75 Sold Brand New non ABS power steering pressure line |
I sent ya a PM
What year throttle body is it? 88 & older or 89 & newer?
Thanks! |
Everything is from a 1993 22RE 5 speed
Also have a Fan shroud |
How close is this to a 1990 22re wiring wise0 what do you want for ecu and engine harness?
Location is Austin Texas.
Only have the ECU no harness Still got this stuff. I'm gonna take pics later and post it all up so I cna get it all gone |
I might be interested in the intake with sensors. Would you have any of the harness-plugs that go with those sensors? Many of my plugs are broken or missing the capture-wire that holds them in place.
I also need a pickup coil from the distributor, seen above my thumb here with the green plug attached: http://i207.photobucket.com/albums/b...psxiy3fzsv.jpg |
bump for that pick up coil and some other intake/ignition parts.
Hey Clay, I sold the dizzy and coil awhile back. Sorry i couldnt help
Still have the ecu and throttle body with TPS? i have a 1987 22re 5 speed 4runner
Pm sent as well
| All times are GMT -8. The time now is 09:28 PM. |
