22RE Fuel Hose w/Damper
2 Attachment(s)
Factory high pressure hose from filter to fuel rail with pulsation dampner. Converted mine to braided hose with AN fittings. Will need new crush washers for install.
Hose factory P/N - 9092301326 Dampner factory P/N - 2327070010 $125 shipped. |
How did you do the fuel line conversion?
I got a fuel rail from LCE that was tapped for AN fittings. Made a braided hose from the filter to the front inlet of the fuel rail with AN6 fittings eliminating the damper. At the other end, removed the FPR from the fuel rail and made a hose going to an adjustable FPR I got off ebay. Think it was an Aeromotive unit. The tricky part is mating up to the solid return line going back to the tank. I think I had to use and AN4 compression fitting, then adapt it to the AN6 coming from the FPR. If it ever stops raining here, I'll try and get you some pics.
| All times are GMT -8. The time now is 10:16 PM. |
