YotaTech Forums
-   Engines - Transmissions (https://www.yotatech.com/forums/f107/)
-   -   WTB[MidWest]: 1990 w56 Transmission Clutch Hub No. 2 (https://www.yotatech.com/forums/f107/1990-w56-transmission-clutch-hub-no-2-a-303617/)
Montana Mar 1, 2018 01:47 PM
I need a Clutch Hub No.2 (the first hub on the shaft) or a junk W56 that someone would be willing to let go for cheap that's in the Midwest. I broke mine trying to press it on :bang:
The image below shows what it is and where its located. The part number is 3336222020.
Thanks.https://cimg6.ibsrv.net/gimg/www.yot...f7baa65227.jpg
atcfixer Mar 13, 2018 10:46 PM
Do you know if a W46 would have the same part? Trans was from a 1990 2wd pickup that I replaced for a guy. Main bearings are worn but from memory all the gears looked good.
Montana Mar 15, 2018 12:40 PM
I'm not sure if it would be the same. Are you trying to sell it as a whole or willing to part it out?
