YotaTech Forums
-   Tool Time (https://www.yotatech.com/forums/f106/)
-   -   Welder/ing (https://www.yotatech.com/forums/f106/welder-ing-199852/)
peow130 Dec 25, 2009 04:34 PM
Welder/ing
So, i'm looking at picking up a 220V Stick welder
Most notably: http://www.lowes.com/lowes/lkn?actio...=cr&lpage=none
My 115V Mig won't do the spring perches that i want to do, or any other thick metals (above 1/4" penetration is meh).
How thick, exactly, will that 220V arc welder penetrate?
toyodually Dec 25, 2009 06:06 PM
specs say 5/32" so i guess roughly a 1/4", that kinda lincoln is what i used in shop class to build my trailer with. worst case you have to make a few extra passes. and run stringer beads to go deeper no motion to the weld pattern, then for looks you can cap it with the mig. just clean everything really good.
peow130 Dec 25, 2009 07:03 PM
do you think it would do well at welding 1/4inch thick spring perches onto axles?
toyodually Dec 25, 2009 09:36 PM
it should i dont see why not, those are good little welders. just make sure you have the right kinda plug for it. not the trusty ole dryer plug, that could burn up the wiring in the wall.
eventually when i get the money and parts im going to sas my toyota and im gonna use a generator welder.
peow130 Dec 26, 2009 12:16 AM
Cool.
Thank you very much.
I tried welding some perches onto a set of axles. I got it hot enough for decent penetration into the perch itself (it was about 1/4" steel), but after i tacked it i lifted the spring off it so i could roll the axle back out, and the darn thing just fell right off.
Looks like i'm hitting up a few stores tomorrow for this tombstone-lookin piece of machinery.
Green_slime Dec 26, 2009 12:55 AM
i am a mech/welder for the army and we have a 220v lincoln yes it will weld up to half inch depending on the rod you use for the root pass you will want a 6010 rod has deep penetration it wont look good at all but then over that you can use either a 6013 or a 7018 either one will make a nice looking bead over the 6010
91 4Runner Dec 26, 2009 12:57 AM
A friend of mine has one of those and he and I have both used it alot (before I picked up my old Forney)... It be plenty heavy enough for what you need.... With the proper prep you can weld thicker material (bevel the edges and clean the work surfaces etc.)
Good luck with your purchase and what you build with it!
toyodually Dec 26, 2009 07:12 AM
Originally Posted by peow130 (Post 51316243)
Cool.
make sure you hit both surfaces evenly. you cant really just burn through the whole spring perch into the axle. you need to put your bead in the corner that the pieces make.
something like the pick below
http://www.weldingtipsandtricks.com/...rrow-other.jpg
peow130 Dec 26, 2009 01:46 PM
yeah i know, i did do that, lol.
edges were bevelled too.
it had great penetration on the perch, little to none on the axle.
Also: Thanks slime for the rod tips.
I'm not worried about looks, as long as the darn thing stays on there.
Hehe, bought the thing today.
Total came to around 294
93YotaMonster Dec 26, 2009 04:33 PM
what kind of wire are you using on your 110v peow?
ethanp123 Dec 26, 2009 05:41 PM
ya i'd use a E6010 OR E6011, using the whip and pass technique then cover it up with either mig or E7018.
93YotaMonster Dec 26, 2009 06:07 PM
you can do it with the mig it just takes a little longer and a little more skill. you can triple pass it, wen i was in school for welding we had to do a multi pass t joint, first the root, then a stringer on the bottom, then one on the top to tie it all together. and there shouldn't be a butt crack in the center of your weld it should flow together even.
peow130 Dec 26, 2009 10:43 PM
.035 wire.
When i tacked it there was no stick at all, and i held it there a good 5-10 seconds at full power. I barely touched it and the thing just slid right off. Not to mention i also aimed it more at the axle (thicker metal), than the actual perch.
Also: Can't use E6010, that's DC only. The AC-225 is only AC, so i'm gonna use E-6011. I guess it has the same characteristics, just a ton of splatter.
ethanp123 Dec 27, 2009 04:31 AM
yes you are right 6010 and 6011 are basically the same rod. I think you have your settings off or something with your mig, because you should be able to lay down a good bead with just that little welder, i'd suggest cranking the voltage and doing a nice slow weave using a drag travel angle so you get more penetration for your root pass then follow it up with two more!
Green_slime Dec 27, 2009 05:09 AM
with your mig does it take argon gas or not because if not and you didnt get it to stick that means that you didnt use flux core wire and i should have said that 6010 was dc only the welder we have has both ac and dc sorry about that
93YotaMonster Dec 27, 2009 02:33 PM
hey poew is your .035 wire flux core or are you using solid wire with 75/25 gas? argon /C02
peow130 Dec 27, 2009 06:17 PM
Flux core.
Look guys, it's not that big of a deal.
I can lay down a good bead, but that welder won't heat up the axle tube hot enough to actually get any good penetration.
If the tack weld that got held there for about 5 seconds wouldnt penetrate, i'm not going to try and lay down a bead with it.
wyoming9 Dec 27, 2009 11:53 PM
Good luck with your New welder although I would have held out for a AC /DC unit but I am spoiled by not having to weld AC for a long time.
It can be a real pain out of position at times :welder:
peow130 Dec 28, 2009 01:59 PM
that 6011 works in all positions..
milehigheric Jan 12, 2010 02:22 AM
I know this thread is a little old, but when I linked mine I tacked the brackets in, then heated the axle with an oxy torch. The axle isn't actually that thick, its is just high tensile. Give it a little heat first and it is much easier to get a good weld on.
I am using a lincon 180 MIG for all my work...I don't think I would touch chassis/axel work with anything less. 115V is really only good for panel work IMO.
