YotaTech Forums
-   Tool Time (https://www.yotatech.com/forums/f106/)
-   -   Torque Wrench? (https://www.yotatech.com/forums/f106/torque-wrench-103920/)
davemacneil Jan 12, 2007 11:34 AM
Torque Wrench?
Should i go with the larger 1/2"? Girlfriend is getting me a present and i want to get something that I can't pull myself to buy. I will prob be doing an engine rebuild in the spring or summer.
3/8"-drive torque wrench, with 25 - 250 lb. torque setting
1/2"-drive torque wrench, with 30 - 250 lb. torque setting
Lifetime manufacturer's warranty
mastacox Jan 12, 2007 11:40 AM
Go with 1/2" drive, since most bolts that have torque requirements in that area will require a 1/2" drive socket anyway, and you can use a 1/2"-3/8" adapter if need be.
davemacneil Jan 12, 2007 11:54 AM
thats my thoughts, thanks, always a good idea to double check when it only takes a second. thanks YT
waskillywabbit Jan 12, 2007 11:58 AM
Get a small setting one too, as a lot of bolts take 25 ft-lbs or LESS.
:guitar:
mastacox Jan 12, 2007 12:00 PM
If you want a 3/8" torque wrench, make sure it handles much lower torques, like 1-50 ft-lb... I need to get me one of them as my Craftsman 1/2" TW only goes down to 25...
Jacket Jan 12, 2007 12:50 PM
Yea - you really need one of each. I've got a 3/8" that goes from 20-100, and a 1/2" adapter that I use as needed. But I wish I had a 3/8" that covered torque's from 5-20 or more, and then a bigger 1/2" for the larger jobs.
AxleIke Jan 12, 2007 02:16 PM
I will second one of each. I have 4. One that does upwards of 350. One that does the 25 to 150. One that is like 5 to 70. One that does inch lbs, for gear instals.
