YotaTech Forums
-   Tool Time (https://www.yotatech.com/forums/f106/)
-   -   angle grinders (https://www.yotatech.com/forums/f106/angle-grinders-210395/)
yotarover Apr 24, 2010 03:11 PM
angle grinders
i've went through at least 2 in the last 6 months 1 was a kawasaki 4/1/2" from tractor supply and the other i can't remember . seems they burn up really fast when grinding lots of metal (even with long breaks in between) so what is everyone else using
hilux1026 Apr 24, 2010 04:01 PM
5 inch is the same motor as the 4 1/2 inch grinder but i will say you get what you pay for. I have a dewalt 5" and a makita 5" and a metabo 5". also have the tractor supply ones. They all last but yeah of your cutting 1/4" thick steel and lots of it get a chop saw from TC. This would be better 4 1/2' and 5" are designed for light grade steel basically thin sheet steel or grinding not a lot of cutting.
874runnersr5 Apr 24, 2010 04:43 PM
makita angle grinder!
scuba Apr 24, 2010 04:50 PM
Quit forcing the angle grinder to make a cut and the motors will stop dying.
I've had an Ace Hardware 4.5" for a couple years now. Aside from the stop/hold switch breaking, which was user error, it still works fine even after running through countless sq. feet of 3/16ths plate. I will be buying another one when I decide not having the stop switch is pissing me off enough.
:dj:
peow130 Apr 24, 2010 08:15 PM
I've had a dewalt 4.5" angle grinder for around 4 years now.
It's seen hours of grinding.
It still spins up perfectly.
Protip: Don't push down on the metal when cutting, just let the cutting blade do the work.
Built2Grind Apr 24, 2010 08:28 PM
i bought a ryobi 4 1/2" grinder for $20 at home depot about 3 years ago and i use it all the time, it still works perfect
Tofer Apr 24, 2010 08:37 PM
x2 :saw::saw:
vital22re Apr 24, 2010 08:52 PM
:dj:
exactly!!! How you use your power tools has a huge impact on thier life.
91 4Runner Apr 25, 2010 02:58 AM
5" Mikita after replacing 4 Canadian Tire brand in 4 months (warrentys keep equaling upgrades)... Been abusing the Mikita for about 8 months now with no issues!
dropzone Apr 25, 2010 03:27 AM
My Makita 4" grinder is 19 years old...no issues.
Cordless Ryobi 18 volt, 2.5 years old is nice for the junkyard:D
Take care of your tools and they will take care of you.
yotarover Apr 25, 2010 09:45 AM
didn't use it for cutting much maybe to cut through some 2" pipe but most of it was grinding galvanisation off the pipes or tubes i'd change the disc or wheel before it got to small and give it a rest start again and they would always die with a big burnt out smell then the side handle would fall off and break part of the housing. im asuming it's from overheating but i never used them for longer than 10 mins
yotaman85 Apr 25, 2010 09:54 AM
I use angle grinders every day, literally. I often use DeWalts but I don't like them, their are too big and heavy. My preference is HellCat. they are very slim and light weight and still have 13amp motors. super torque and VERY fast speed. but at $140, they're not cheap.
904_runner Apr 25, 2010 09:59 AM
Im rocking a makita angle grinder, had it since i started my sas.
I think its been through 2 or 3 sas's so far..
4runnerRandy Apr 25, 2010 12:34 PM
Dewalt and Mikita, I use mine to cut tile and concrete and also for fabricaion on the yota. Both are very reliable. I build custom swimming pools and my employees use them alot (tons of concrete, stone and tile cuting), the Dewalt seems to last longer but costs a little more, aslo we have a factory dewalt store here in denver and they waranty them very well and if its out of waranty its not to expensive to get it rebuilt.
2themax Apr 25, 2010 02:46 PM
I have two 5" makita's. Im a pipeline welder so my grinders are used all day everyday. I also run 7" wheels on both. A 7" grinding wheel on one and a 7" wire wheel on the other. Only problem I had was my fault, A rock got in where the fan blade was and when I hit the trigger that was it. I have ran some 5" milwaukee's with 7" wheels and they didn't even last a month. Makita's are a little heavy but very rugged and durable
rocket Apr 26, 2010 01:11 AM
I've had a 4 1/2" Makita for 15 years and put countless hours on it. It eats up steel with force like a grinder is meant to do.
4Crawler Apr 26, 2010 11:47 AM
I use a 4.5" Hitachi grinder and it has held up well in the 10-15 years I've owned it. Did wear out a set of brushes in it, but replaced those about 5 years ago:
- http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
It gets used daily as well.
toyNG Apr 26, 2010 11:51 AM
I've got a 4.5" Dewalt that's been great to me
waskillywabbit Apr 26, 2010 12:22 PM
I've used them all, sizes, brands etc.
My favorite for any job is my 6" Metabo. It is a work horse arse kicking power tool.
Mine has thousands of hours on it.
Cheap power tools are just that.
:guitar:
Hydro joe Apr 26, 2010 01:39 PM
The matebo variable seed grinder is worth the money. I do the worst things you can do and it holds up.
