YotaTech Forums
-   Product Reviews (https://www.yotatech.com/forums/f105/)
-   -   Cool It (https://www.yotatech.com/forums/f105/cool-59308/)
fireman1525 May 17, 2005 03:40 PM
Cool It
Just installed my cool it wrap by Thermo TEch. I saw it advertised to reduce engine temps dramatically. You wrap it onto your header or manifold and strap it down with metal straps. it is like fiberglass and graphite and works great. especially since i just recently put my FIPK in. Cooler engine compartment temps means cooler air, which = more horses and better MPG. I can definately tell a difference in both. Got it from alamomotorsports.com :bigok:
desert whomper May 18, 2005 02:05 PM
eventually tho the heat build up inside your heades caused by that wrap will cause them to get too hot and crack or warp.
fireman1525 May 19, 2005 07:55 AM
Probably
Your Are Probably Right, But The Mechanic I Talked To Said That If I Had Aluminum Headers It Might Eventually Cause Problems, But B/c I Have A Cast Manifold Right Now, It Shouldn't Cause Any Harm Due To The Strength Of The Cast. But If It Cracks It Will Give Me A Reason To Order Headers From Lcengineering!
DudeBud May 20, 2005 12:33 AM
cast cracks easy keep it out of water and you might be ok
