Last edit by: IB Advertising
Browse all: Exterior Guides
- Toyota 4Runner 1984-1995 How to Build Flatbed
Step by step instructions for do-it-yourself repairs
Toyospearo's FLATBED build...
holy moly. that is definately teh nicest flatbed ive seen. teh angles are awesome. its not big and awkward and its not small and inconvenient. its perfect my friend. i want a flatbed like this now
Very nice job.
Looks like you mounted the frame to the original body mounts?
Might want to get a cover for your Hi-Lift. It is gonna catch a lot of extra grime being over the tire like that if you run it there all the time. For trips, not a big deal.
Great job.
Great job.
#26
You mounted the frame on 4 or 6 of the original body mounts? Only saw 4. Great idea to make it removable.
Makes me want to go finish restoring my bed.
Last edited by waskillywabbit; 09-17-2009 at 06:48 AM. Reason: Correcting my wonderful Grammar
#27
The flatbed frame is mounted on all 6 locations. The two mounts right behind the firewall are 1/4" lower than the back 4 mounts. I drilled a hole in the flatbed angle iron to meet up with the stock front holes. I ran a bolt, a 1/4"spacer, lock washer and washer to secure it.
I PM'ed my address!!!
#30
#35
where did you learn all this stuff?
You did a very good job, you should be very proud. I know i would if i made that. Your attention to detail really shows, great job.
#40
That's looks awesome! Looks heavy though, hows the spring rate on those springs holding up? You gunna need new springs? Also, I wouldn't mount the high lift there...too susceptible to gettin smashed on somethin or gettin clogged with mud on a trail when you need it most...just somethin to think about. Trucks lookin great as always.
