bumper build-up
bumper build-up
First off, I have a winch bumper but it sits too low and is too short. I wanted something similar to what SigEp4Runner did. https://www.yotatech.com/forums/f88/...inally-219699/
My original bumper is the first pic and the next is what my plan is.
[IMG]file:///C:/Users/NEILAL%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG]
the old one has brackets set to the bottom of the frame and i added a 3'' body lift. plus the time to add to the old one to make it like the new one would actually be inconvenient. I like the idea, trust me i wish i could...that was my first option
I would use at least 1/4" plate for mounting the bumper on to and the gussets for it. 1/8" is not going to be strong enough for heavy awkward pulls.
my old bumper is 1/4'' and doesn't have any gussets at all plus it's only stitch welded not solid. i figured if i put (4) 1/8'' gussets under the bottom plate and ''skid plate'' it would hold but i may be wrong after all this is my first structural fabbing that i have done so any ideas would be good.
Your bumper is only going to be as strong as what it is attached to.
Are you planning to bolt this or weld this to the truck??
Or are you making your own welded on brackets that the bumper will bolt too.
I also have a tendency to over build things as well.
That is a call only you can make.
Happy fabbing
Happy fabbing
ok so i have figured out what i'm going to do and please correct me if y'all think it can't handle it. i want to bolt my winch to a 1/4'' plate and have that plated welded or bolted on to the front cross member. doing this will eliminate the winch box and i can make my bumper out of 1/8'' and the bumper itself wont have any stress at all.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
Scotttekoch
09-28-2015 10:30 PM
Toys4parts
09-26-2015 01:56 PM
