What did you do to your rig today? - YotaTech Forums
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 07-15-2010, 03:04 AM   #1
Co-Founder/Administrator
Staff
Corey's Avatar
Have seen this done on a few other sites as well.
Pictures would be helpful if you want to share.
I do not do much to my rig during the work week other than driving it back and forth to work.
But I do have work planned for it this weekend.
Interior needs cleaned, but I do intend on organizing some camping gear in there, and moving some other stuff around.
Been meaning too to unspool the winchline and reel it back in, and see if the battery is still good for the winch remote.
Might work on the tent some more too, working on a new shelf for inside.
Corey is offline   Reply With Quote
Old 07-15-2010, 08:17 AM   #2
OK, I'll play along....
toyotasaurus is offline   Reply With Quote
Old 07-15-2010, 08:25 AM   #3
Tofer's Avatar
yesterday i installed Hella 500's with a HID conversion.
Tofer is offline   Reply With Quote
Old 07-15-2010, 08:57 AM   #4
Licensed Lunatic
iamsuperbleeder's Avatar
pics or it didn't happen?
iamsuperbleeder is offline   Reply With Quote
Old 07-15-2010, 09:01 AM   #5
Tofer's Avatar
i need to finish wiring the switch but i'll take pics once its done. i hooked them up just to see it work and HOLY crap they are bright!
Old 07-15-2010, 09:02 AM   #6
UKMyers's Avatar
Sunday I started my rig for the first time in 2 months, revved the engine, and blasted some tunes through my 10 speaker 1000watt system...poor poor crawler. Baby girl is just about old enough for her first wheeling trip though so time to pull it out of the garage and use the dang thing this summer for a change.
UKMyers is offline   Reply With Quote
Old 07-15-2010, 09:08 AM   #7
Tofer's Avatar
nice!
Old 07-15-2010, 09:09 AM   #8
BT17R's Avatar
Funny you should ask. I went at the FJ this week big time.
-- Changed oil and filter with Mobil 1 0W-40
-- Changed ff/rr/center diffs, t-case and tranny to Redline synthetics
-- Greased driveshaft U-joints and sliders (6 zerks)
-- Full Griot's polish and wax for paint
-- Mother's Back-To-Black all exterior plastic
-- Mother's Conditioner interior plastic
-- Wheel brush and car wash soaped upholstery, great results
-- Blech-White tires (3 times) to restore letters and flat carbon finish
-- Will polish exterior glass with Griot's Glass Polish and buffer today
It's looking spiffy. When I came out of Office Depot today some guy with a 3rd Gen 'Runner was taking a pic while another guy was looking inside admiringly so I answered questions and felt quite chuffed.
None of this was deferred maintenance. I'm getting ahead of the curve while waiting for clutch v.3.0 TSB (warrantied free like the last one) to arrive at the dealership any day. Meanwhile I'm trying to avoid driving it since the gears are grinding on upshifts.
BT17R is offline   Reply With Quote
Old 07-15-2010, 09:22 AM   #9
UKMyers's Avatar
Soft scrub with bleach and a good brush works killer on white tire lettering.
Old 07-15-2010, 09:25 AM   #10
Staff
Corey's Avatar
I use Ajax and a scrub brush on the tires each time when I wash it.
I also spray Bleach White on it too.
Learned the Ajax trick from my dad long ago.
This is what most firehouses use to clean their firetrucks tires with.
Old 07-15-2010, 10:05 AM   #11
metalhed's Avatar
Fixed broken battery box and wires. Need new battery, fell against the superchager belt and now has a hole worn in it.
metalhed is offline   Reply With Quote
Old 07-15-2010, 10:35 AM   #12
Fink's Avatar
That's what we used to use at the FD.
I drove mine today, that's about it.
It needs a detailing badly though - I'm tied up for the next few weekends unfortunately.
Fink
Fink is offline   Reply With Quote
Old 07-15-2010, 10:41 AM   #13
Swimmerboy2112's Avatar
-Replaced the alternator
-Replaced the battery
-Replaced the battery again
-Checked the wiring
-Checked more wiring
-Got the battery tested
-Pulled the alternator
-Pulled the starter
-Gonna get them tested again
Swimmerboy2112 is offline   Reply With Quote
Old 07-15-2010, 11:03 AM   #14
OrRunner's Avatar
im in, scrubed bolts, painted oil pan and clear coated a freshley bead blasted valve cover, all for the new motor. Going to be putting the long block together tommorow and sat i hope...
OrRunner is offline   Reply With Quote
Old 07-15-2010, 11:36 AM   #15
1981 yota's Avatar
i did simple stuff today
put new spring for the throttle return
fixed mudflaps
1981 yota is offline   Reply With Quote
Old 07-15-2010, 12:22 PM   #16
yotawheelin95's Avatar
Put a tachometer in the 4runner as well as replaced both reverse lights. I found it odd for both to go out at the same time....
yotawheelin95 is offline   Reply With Quote
Old 07-15-2010, 12:48 PM   #17
lofreqjeff's Avatar
I left it at home in the garage while I went to the office today - what a bad dad I am
lofreqjeff is offline   Reply With Quote
Old 07-15-2010, 01:32 PM   #18
leebee's Avatar
did rr brgs last weekend (major pita), yesterday checked all fluids, belts & hoses, lubed all door hinges, locks, gate window track, parking brake pivot points, shift linkages and shot all the rust spots i could find. gotta try and keep the body from deteriorating any further until i can get it in for some new sheet metal. today got it e-tested, new sticker, determined it needs new shocks up front. tomorrow, check with stealer if new bolts for t-case xmember are in.
good news, brakes are in great shape!
lee
leebee is offline   Reply With Quote
Old 07-15-2010, 01:35 PM   #19
Licensed Lunatic
I turned my truck around in the driveway, that's about the extend of it I'm lame...
Old 07-15-2010, 02:00 PM   #20
dannomite's Avatar
replaced leaking right rear wheel seal
extended rear diff breather to firewall
discovered that my positive battery cable end is cracked and needs replacing
dannomite is offline   Reply With Quote
FS[NorAtl]: Parting 93 3.0 Exta-cab 4x4,auto ToyotaMD Vehicles - Parting Out 28 09-08-2016 11:21 AM
Late intro pickle6415 Introductions & New Arrivals 2 09-14-2015 01:24 PM
PLEASE HELP!?!?!? No fuel 22re Cwolfe 86-95 Trucks & 4Runners 5 09-12-2015 12:23 PM
bleeding master cylinder problems old87yota 86-95 Trucks & 4Runners 20 09-09-2015 12:39 PM
RuffStuff's LABOR DAY SALE! Gravel Maker RuffStuff 1 09-08-2015 05:46 AM
Tags
275001, 30vze, allpro, diagram, engine, flatbed, harness, kit, locker, parts, pick, pioneer, relay, rig, virginia, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
What's your question?
