drive shaft fell out 2008 ford ranger - YotaTech Forums
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 05-18-2017, 07:03 AM   #1
I just had my transmission serviced ,rear end serviced and replaced both universal joint. Drove to work three days and was at a turn signal to turn left and the drive shaft fell out. I had to push the car into a parking lot call the mechanic to have it brought back to his repair shop. He said it took 6 guys to push it in the shop that he thinks the problem was the brakes that caused the new universal joint to fall out. I push the car myself I'm a 5'3 girl and pushed it down the street into a parking lot with the door open so I could steer. I looked under the car and I can see the new universal joint still bolted to the rear end but the part for the dive shaft is missing the cups. Its like they forgot to put the retainer clips on the universal joint. I know my old one had clips because I seen them. Can someone tell me what caused this ,the repair shop said he he thinks its my brakes I call B/S because everything worked fine and I pushed it my self so they were not locking up.
Last edited by helpadudeout; 05-18-2017 at 07:14 AM. Reason: forgot to ask the question
helpadudeout is offline   Reply With Quote
Old 05-18-2017, 07:21 AM   #2
arlindsay1992's Avatar
Not sure how your 2008 Ranger problem ended up on a 86-95 Toyota forum, but what you said sounds spot on. With the clips installed correctly the caps would never walk out. The clips may not have been fully seated in the groove. Brake problems would also never cause that. If so, everytime someone locked up their brakes in a panic stop we'd have driveshafts flying. Be prepared to deal with the fact you're a woman and they'll assume you don't know what you're talking about.
arlindsay1992 is offline   Reply With Quote
Old 05-18-2017, 07:59 AM   #3
Thanks so much for that and to answer why I'm on this site I just put in drive shaft problems and this site came up.
Thanks again for your input.
[Colorado] Built 1986 Turbo SR5 4Runner **SOLD** sevenphoenix The Classifieds GraveYard 1 05-20-2017 09:47 AM
Altitude questions... thechief86 Pre 84 Trucks 20 03-07-2017 01:06 PM
Big Bear trail with a GX470 civicferio Trip-Trail Reports & Photos 6 09-06-2004 10:38 PM
How many times must we tell the tale. amusement Off Topic Talk 5 02-01-2004 06:14 AM
89 4runner will 302 ford fit ? duanedeidre 95.5-2004 Tacomas & 96-2002 4Runners 4 11-08-2003 02:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
What's your question?
