California NorCal California NorCal Chapter
Removable top window
Old 09-22-2012, 07:49 AM
smooretahoe's Avatar
I have an 1988 4runner with the removable top with rust around the sliding window, I was looking for a new top but can't find one to save my life. Is it possible to replace the window? If so, where would I find one? The black part around the L bracket is toast....any suggestions?
Old 09-22-2012, 11:03 AM
BigBluePile's Avatar
You can just replace that L bracket. It's just double sided taped on.......
Old 09-22-2012, 01:35 PM
Staff
DeathCougar's Avatar
I think the L-bracket he is talking about is the one that rusts out on our 4Runners. The outside metal trim piece on the sliding glass. In that case, its screwed on the window frame not double sided taped. You have to remove the window assembly to access the screws.
Toyotafiberglass.com makes replacement pieces, and you can also find them used.
Old 09-22-2012, 06:15 PM
.....with screws.....whatever. You still have to pop the window out to get to the screws.
Old 09-23-2012, 08:20 AM
Staff
You don't haaaaave to. You could always drill some holes in the fiberglass
Wouldn't look very good though. May leak a tiny bit.
Old 09-23-2012, 04:06 PM
There's a tiny leak between your ears
Old 09-23-2012, 05:17 PM
Staff
Sorry, can't hear you
Old 09-23-2012, 05:22 PM
Duh..... this iz the internetz
jasonty
41
12-23-2018 01:00 PM
RustBucket
07-24-2015 04:46 AM
icentropy
07-14-2015 10:23 AM
crashburnoveride
07-10-2015 06:39 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: Removable top window
