lighting issue
Ok, so you are saying that only the rear passenger side turn signal does not work, did you pull the bulb and check it? Sometimes you can visually see that the filament is broken, but if it looks ok, you can swap it to the other side and see what that does.
onmyway
08-04-2016 12:57 PM
