Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
HELP MY 87_4×4 sr5 pickup. Won't start
Old 05-09-2017, 02:39 PM
Daniel Kirkpatrick's Avatar
Old 05-09-2017, 06:22 PM
bootscootboogie's Avatar
Make sure it has an engine in it.
I'm kidding! Post details and I'm sure people will chime in. What engine do you have? Is it turning over at all?
Fuel? Spark? Air? Have you seen this truck run before?
The more details you put on here, the better advice you're gonna get.
Old 05-09-2017, 06:46 PM
I got fuel i got air new plugs brand new cylinder head and new gaskets vacume lines are hooked up to the best of my knowledge and long searching electrical plugs are back in there spots truck ran even with piston234 flooded with coolant or atleast they was when i pulled old head out i have some marks on my pulley for tdc but also other marking dented in to it mind you this i purchased this truck with a bonded title and it doesn't have its original year engine in it is what i was told
Old 05-09-2017, 06:47 PM
Thanks any help i will take in and check if havent already
Old 05-09-2017, 10:18 PM
RAD4Runner's Avatar
A few periods would help you fix your problem. Pls write in proper English. This is America.
Old 05-09-2017, 10:29 PM
Didnt know i was in English class thanks professor on that note ..............
There you go if you dont like the English that was written than read another person's question thanks for your input but i am american and i would appreciate some respectable comments not childish ones
Old 05-09-2017, 10:36 PM
But. anyway here is some pic and more discription and details .
Old 05-09-2017, 10:38 PM
am new to being a owner of a toyota and i had a blown headgasket ..so after some time, i gathered up enough money and purchased a new cylinder Head and gasket set .This is the old cylinder head.
New gasket, cleaned head .
New cyllinder head on new gasket .
Almost finished at this point i was saveing more money for new vacume hoses and new v belts,new throttle cable. But all this is my first rebuild , with not much knowledge on toyota or really any thing this deep in maintenance .after lots of searching and diagram after diagram .ect everything is in the right spot to my best knowledge (no leaks im getting fuel all my plugs are back were they came off of but my truck wont start it almost sounds like it is close to starting but nothing checked my plug wires and set timeing on distributor and engine at tdc any advice will help
Old 05-09-2017, 10:56 PM
Just removed cylinder head and started cleaning engine block
I just kept everything together after tear down inbetween rebuild
Painted and new cylinder head and gaskets front view
Same side view
Dotting my i's and crosing my t's with wire harness and vacume lines i timeing is set to my best know how and i just had to charge my battery becuse i tryed starting it a lot guna replace battery tommorrow with new one and pray hard to the man up stairs to get me back on the road / trail. Where ever this baby can take me
Still at it pic took min after last one
Toyorain
10-26-2018 07:09 PM
Dreedy1976
05-02-2017 08:25 AM
irv
04-23-2017 11:54 PM
firepilot
04-07-2017 09:39 PM
Joseph.from.sd
03-08-2017 01:34 PM
Quick Reply: HELP MY 87_4×4 sr5 pickup. Won't start
