Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Tube Shock Towers!
Old 04-19-2016, 09:32 AM
FormerVendor
Gravel Maker's Avatar
Tube Shock Towers!
Here is a pair of 1.5"x.120 wall DOM shock hoops. These are not the typical both sides even type everyone else makes because often your mounting surface and where you need to mount them simply have to be different. These make it easy to mount them tilted forward or rearward and have enough tube. If you are one of the lucky few that can mount them straight up and down just cut off the extra tube!
They come with two pair of our curved shock tabs so you can fine tune the height adjustment by the position of the tabs.
Shock Hoop 1.5" - RuffStuff Specialties
Old 06-08-2016, 02:33 PM
FormerVendor
Adaptable to just about any Toyota!
Old 08-30-2016, 04:53 PM
FormerVendor
Time to get it done!
Old 09-07-2016, 08:06 AM
FormerVendor
Take the guess work out!
Old 09-26-2016, 08:05 AM
FormerVendor
This is what you need.
Old 10-07-2016, 09:02 AM
FormerVendor
Work these into your next build or re-build!
Old 10-24-2016, 08:46 AM
FormerVendor
Great on buggies, to stock(ish) rigs.
Old 11-16-2016, 08:07 PM
FormerVendor
The right pieces are what you need!
Old 11-28-2016, 06:39 AM
FormerVendor
Simple, easy and incredibly effective. That is what you need.
Old 01-05-2017, 06:47 AM
FormerVendor
The right way to get it done!
Old 05-18-2017, 04:16 PM
FormerVendor
Front or rear, where ever you need it!
