Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Toyota T100, 1995+ Tacoma and 1999-2006 Tundra HD Diff Cover from Barnes 4wd!
Old 07-07-2016, 04:10 PM
FormerVendor
Barnes 4wd's Avatar
Toyota T100, 1995 and Newer Tacoma and 1999-2006 Tundra Heavy Duty Differential Cover
Barnes 4WD is proud to introduce the first Toyota Diff Cover that offers complete protection for your third member, maximizes clearance and increases fluid capacity. This cover is not your typical cap that you just weld over the thin stock housing. With our cover you completely remove the factory cap (a quick job with a cut off wheel) and weld a laser cut and bent ¼" A50 Plate Steel cover in its place. This is a little more work but the payoff is worth it for the total coverage and increased oil capacity. Covers ship fully welded with a large fill plug so all you have to do is prep your axle and weld it on! This is also the most economical fix for a rusted leaking Toyota rear axle. This cover looks slightly different than the factory cover, but rest assured it will fit the applications listed below.
This cover will fit.
1993-1998 Toyota T100 Truck
1999-2006 Toyota Tundra
2001-2007 Sequoia
1995-2014 Toyota Tacoma without E-Locker
Click Here To View Our Toyota T100, 1995 and Newer Tacoma and 1999-2006 Tundra Heavy Duty Differential Cover
Old 07-18-2016, 12:00 PM
FormerVendor
Barnes 4wd's Avatar
We hope everyone had a great weekend!
Old 07-22-2016, 09:55 AM
FormerVendor
Barnes 4wd's Avatar
Friday is finally here!
Old 08-04-2016, 06:54 AM
FormerVendor
Barnes 4wd's Avatar
Another busy week almost coming to an end! Thanks everyone!
Old 08-10-2016, 08:30 AM
FormerVendor
Barnes 4wd's Avatar
Thanks for the orders today!
Old 08-18-2016, 05:35 PM
FormerVendor
Barnes 4wd's Avatar
Friday is right around the corner!
Old 08-24-2016, 01:08 PM
FormerVendor
Barnes 4wd's Avatar
Midweek bump!
Old 08-31-2016, 02:51 PM
FormerVendor
Barnes 4wd's Avatar
Get in the shop and start building!
Old 09-12-2016, 10:23 AM
FormerVendor
Barnes 4wd's Avatar
We were pretty busy this weekend!
Old 09-19-2016, 04:16 PM
FormerVendor
Barnes 4wd's Avatar
Another extremely busy Monday!
Old 09-28-2016, 05:04 PM
FormerVendor
Barnes 4wd's Avatar
Keep those orders coming!
Old 10-04-2016, 03:07 PM
FormerVendor
Barnes 4wd's Avatar
Our shipping guys were busy today!
Old 10-24-2016, 11:25 AM
FormerVendor
Barnes 4wd's Avatar
Thank you for another busy weekend!
Old 11-02-2016, 05:50 PM
FormerVendor
Barnes 4wd's Avatar
Midweek bump!
Old 11-14-2016, 12:17 PM
FormerVendor
Barnes 4wd's Avatar
Tofer
12-11-2015 03:48 PM
kryptik
07-12-2005 10:39 PM
Quick Reply: Toyota T100, 1995+ Tacoma and 1999-2006 Tundra HD Diff Cover from Barnes 4wd!
