Toyota 8" Back Truss!
FormerVendor
Here we are, along the same lines of all our Crowned Trusses. This is the truss all Toyota guys have been waiting for!
This one, just like all of ours is shaped for maximum strength. The Crowned back will help keep your axle straight for years to come and if you combine it with the top truss you can feel free to jump it!
The truss is made from 3/16" steel and the fill hole access port completely protects the plug. They are meant to be welded full length. Start in the middle with 4" welds on top and bottom then heavy tack it everywhere. Then work from the outside in with 3" stitches alternating top to bottom until done.
These are setup to reach the full width of the axle housing on mini-truck axles, which is ideal for those who are going with links, and don't need a spot for the U bolts and perches. However we do send you an end cap that is left extra tall, so if you don't want the truss to go full width, then you can trim is shorter and the end cap still has the meat left to work with.
These are slightly thicker than the housing and will definitely make that axle last til you are ready!
Toyota Mini Rear Back Truss - RuffStuff Specialties
