Serious Armor from RUFFSTUFF!!
FormerVendor
This is another one of our "million different uses" type products! Our Universal Tube reinforcements are meant to add wall thickness to your tubing ONLY where you need it! Great for tie rods, lower links, rock sliders, roll cages, and everywhere in between!
•Saves tons of weight and money versus building full sections out of heavy wall tubing.
•The bending and welding makes this reinforcement harder than the tubing it is covering! No more denting tubes.
•Replaceable! If you wear through the reinforcement simply cut along your weld to remove it and weld a new one on.
•Easier and stronger than cutting out and splicing in new sections of cage or rock sliders if a tube is punctured or scraped through!
•Fits on 1.5", 1.75", and 2"+ diameter tubing
•46" length is long enough to cover most full-width axle tie rods from tube insert to tube insert, 1-3/8" wide, 3/16" thick (makes your .25" wall tubing 7/16" wall!)
Universal Tube Reinforcement (Single) - RuffStuff Specialties
MudHippy
02-07-2016 08:02 AM
