Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Ruffstuff's 14 Bolt Pinion Guard & Truss Bridge!
Old 05-03-2016, 08:55 AM
FormerVendor
Gravel Maker's Avatar
This is an easy decision. The welds on the 14 Bolt tubes have been known to fail when you have high HP so this bridges the strength gap.
This comes as part of our 14 Bolt Truss Kit but it is very easily adaptable to any truss made by a shop or a home Fabricator. It has enlongated holes so it can be used with any companies Pinion Guard, our Pinion Guard, or with no pinion guard.
The Bridge has 2 weld in Gussets to eliminate any flexibility.
The Pinion Guard Adapter comes with bolts for the Truss end but not for the Pinion end. We do not add them because GM used 2 different threads over the years and not every Pinion Guard has the same thickness as ours. This will work with any Pinion Guard or Truss.
[url=http://www.ruffstuffspecialties.com/catalog/diffcovers.html[/url]
Old 08-23-2016, 02:55 PM
FormerVendor
What your 14 bolt needs to serve you well for many throttle blips to come....
Old 09-27-2016, 11:37 AM
FormerVendor
Gone to the might 14 bolt in the rear? Make it last and save yourself the PITA of replacing U joints on the trail!
Old 10-19-2016, 01:54 PM
FormerVendor
Armor up your 1 ton axle!
Old 11-04-2016, 10:44 AM
FormerVendor
Protection where you need it most!
Old 11-24-2016, 09:43 AM
FormerVendor
It's a manly safety blanket for your U joints!
Old 01-05-2017, 06:49 AM
FormerVendor
Some upgrades, just need to be done!
Old 07-23-2018, 06:13 PM
FormerVendor
Got a toy on a ton?
