Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Ruffstuff 3 Link Kit!
Old 04-14-2016, 06:47 PM
FormerVendor
Gravel Maker's Avatar
We have here everything to create a 3 link suspension, front or rear, and not low end stuff just to be cheap either! The kit is wrapped around 6 of our 1.25" Heat Treated Chromoly Heims with Zinc Plate or Stainless Steel High Misalignment, Zinc Plated Jam nuts, and 1.5" Tube ID Weld Bungs. You also get another set of Heim joints in 7/8" for the Panhard. You get our Chassis Link Brackets and 10 Degree Axle Brackets for the lower arms. Then a choice of Upper Link Tower at either 0, or 10 degrees left or right. Again you have a choice of 0, or 10 degrees for the frame side 3 Legged Bracket to finish it off.
We finish the Kit off with your choice of Pan-Hard Brackets. We offer two styles for the Frame side, and 2 styles for the Axle side, each with (3) 9/16" Bolt holes so that you have an easy time making the geometry work.
You can choose to order the kit with or without tubing because you will often save a lot of money buying your tube locally when you add the shipping cost of the tube, 2" x .25" wall DOM weighs over 4.5lbs a foot!
If you need to change anything give us a call and we can mix & match til its right for you! We do have DOM as an option but always price it locally first...
Old 07-08-2016, 02:45 PM
FormerVendor
Time to get that Front (or Rear) End Linked up!
Old 08-17-2016, 11:36 AM
FormerVendor
GREAT PRICE STRONG PRODUCT
Old 09-08-2016, 02:52 PM
FormerVendor
Today is the last day to cash in!
Old 09-17-2016, 11:33 AM
FormerVendor
Get your truck flexing and cycling!
Old 09-20-2016, 11:29 AM
FormerVendor
We've got so many choices of brackets, so that you can get the ones your really need!
Old 10-08-2016, 10:24 AM
FormerVendor
Design your kit that way that you want it!
Old 10-24-2016, 08:46 AM
FormerVendor
you can make the geometry of your links work out any way you like...
Old 11-16-2016, 08:07 PM
FormerVendor
Build it right instead of multiple times....
Old 12-26-2016, 03:15 PM
FormerVendor
All the pieces you need to make a bitchin 3 link are right here in one kit!
Old 02-18-2017, 07:28 AM
FormerVendor
Pick and choose the right parts to make the 3 link really YOURS, not just one off the shelf!
Old 05-17-2017, 06:27 AM
FormerVendor
Tree Link.
[/size\]
Old 09-26-2017, 11:18 AM
FormerVendor
The best choice for front suspension.
