Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Poly Bushing Kits from Barnes 4wd!
Old 07-07-2016, 04:29 PM
FormerVendor
Barnes 4wd's Avatar
Poly Bushings and Bushing Kits from Barnes 4WD
This is a great kit, made from 2" DOM with a ¼" wall and a high quality poly bushing inner sleeve bore is 9/16" or 5/8” which gives you a very thick wall thickness that will not become egg shaped with hard use. This combo is great for any application that you need to isolate vibrations. These can be used for motor mounts, cage mounts, transmission and transfer case cross members and many other applications. Our DOM Sleeve with Poly Bushing comes in two lengths. Like all of our products, they are made in the USA from USA steel.
This is what you need to make that crossmember bulletproof and still vibration dampening, it comes with everything and is made of 2.0" DOM with a .25" wall and .375 Tabs for frame mounting (we can replace with 1.75" or 2.0" Radius Tabs for tube mounting). It comes with 2 grade 8, 9/16" bolts with Lock nuts, 4 high quality Bushings, and an inner Sleeves Cadmium coated. They are 3" wide. Sold in pairs.
Our single poly bushing kit comes with two bushings and one inner sleeve. The inner sleeve has a bore of 9/16" or 5/8” which gives you a very thick wall thickness that will not become egg shaped with hard use. The bushings are designed to fit a 1.5" ID tube.
Click Here To View Our Poly Bushing Kits
Old 07-15-2016, 08:56 AM
FormerVendor
Barnes 4wd's Avatar
Quality you can trust!
Old 07-21-2016, 10:02 AM
FormerVendor
Barnes 4wd's Avatar
The weekend is right around the corner!
Old 07-26-2016, 01:21 PM
FormerVendor
Barnes 4wd's Avatar
Build it right the first time!
Old 08-08-2016, 07:55 AM
FormerVendor
Barnes 4wd's Avatar
Get your upgrades at affordable prices!
Old 08-15-2016, 10:32 AM
FormerVendor
Barnes 4wd's Avatar
Hope everyone had a great weekend!
Old 08-21-2016, 04:45 PM
FormerVendor
Barnes 4wd's Avatar
We love staying busy!
Old 08-26-2016, 11:38 AM
FormerVendor
Barnes 4wd's Avatar
We hope everyone has an excellent weekend!
Old 09-01-2016, 03:22 PM
FormerVendor
Barnes 4wd's Avatar
Build season is almost upon us!
Old 09-13-2016, 04:07 PM
FormerVendor
Barnes 4wd's Avatar
Tuesday bump!
Old 09-22-2016, 03:41 PM
FormerVendor
Barnes 4wd's Avatar
The weekend is almost here!
Old 09-29-2016, 02:58 PM
FormerVendor
Barnes 4wd's Avatar
Have questions? Call us!
Old 10-07-2016, 11:42 AM
FormerVendor
Barnes 4wd's Avatar
End of the week bump!
Old 10-26-2016, 07:25 AM
FormerVendor
Barnes 4wd's Avatar
Midweek bump!
Old 11-03-2016, 02:21 PM
FormerVendor
Barnes 4wd's Avatar
Don't worry, if you have questions, call us!
Old 11-16-2016, 03:38 PM
FormerVendor
Barnes 4wd's Avatar
Midweek bump!
Tofer
12-11-2015 03:48 PM
kryptik
07-12-2005 10:39 PM
Quick Reply: Poly Bushing Kits from Barnes 4wd!
