Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
89-95 22RE/3VZE upgrade fuel injectors -free-
Old 05-04-2014, 04:40 PM
  #41
thefishguy77's Avatar
I received mine Friday evening. Install starts tomorrow morning.
Thanks again Flame Thrower.
Old 05-04-2014, 05:43 PM
  #42
twistedyota's Avatar
Originally Posted by Flame Thrower
your stock injectors do an OK job. but having a better spray pattern makes a large difference in part-throttle driving, which is all most of us ever do.
your engine burns fuel vapor, not raw fuel. the closer the fuel is to vapor in the first place, the better. you get a bigger, harder bang with a cleaner burn that gives you more power and better throttle response. its not magic, it's combustion physics.
Quick question, normally with more power your emissions get worse, so will ones smog readings be worse with these?
Old 05-04-2014, 06:59 PM
  #43
Yotard's Avatar
I received mine on Friday bought an intake gasket today. I will be working this coming weekend on it. Reading through the fsm thanks flamethrower.
Old 05-04-2014, 07:43 PM
  #44
4runrjunkie's Avatar
sent you a pm a couple days ago but figured I should it here. This is an amazing opportunity so if you decide to pick me for one of these sets I would be incredibly grateful Thanks!
Old 05-04-2014, 07:45 PM
  #45
My assumption would be that you would actually see better smog readings. The additional power is coming from a more efficient spray pattern and therefore more efficient burn, instead of just adding more fuel and air like most power additives. Therefore you would need less fuel for the same amount of power and should see better smog numbers as a result.
Old 05-04-2014, 07:47 PM
  #46
Well said.
Old 05-05-2014, 04:53 PM
  #47
bam671's Avatar
can i be a canidate for Guam almost all the cars and trucks out here are toyota i can help spread the word after
Old 05-05-2014, 05:43 PM
  #48
Chaser Johndoe's Avatar
Thanks, got mine late last week. I'll try to get them in as soon as I can.
Old 05-07-2014, 04:14 PM
  #49
FormerVendor
Flame Thrower's Avatar
that seems to be pretty much how it goes. it is not magic. it is combustion physics. i have had several (maybe 15) buyers who were able to finally pass cali emissions with the upgrade injectors (they were probably running lean). of course, your mileage may vary.
Old 05-07-2014, 04:23 PM
  #50
mbomberz1's Avatar
These not compatible with the 88 3vze injectors because of the plugs being different?
Old 05-07-2014, 04:38 PM
  #51
I got mine comes with pigtail adapters.
Old 05-08-2014, 03:31 PM
  #52
FormerVendor
the 88 is a stand-alone year for the 3vze injectors. it requires the early style (low ohm) injectors with an adapter harness to mate it to the 88 wiring harness. i don't have them listed because too many buyers bought them in error and the injectors killed their ECU.
give me a call at 888-621-0794 and i can get you a set.
Old 05-08-2014, 07:21 PM
  #53
Did not know that, I'll be giving you a call working on my new to me yota
Old 05-12-2014, 05:48 PM
  #54
90YotaPU's Avatar
If you are still looking for testers, I would be more than happy to do it. I didn't post originally due to my lack of post count.
Old 05-13-2014, 01:55 AM
  #55
bam671's Avatar
flamethrower i sent you a pm and posted on this thread can you let me know im still very interested
Old 05-21-2014, 11:55 AM
  #56
AdmiralYoda's Avatar
A little late to the party but PM sent......
Old 05-21-2014, 04:19 PM
  #57
Old Tow's Avatar
I don't have the required 50 posts as I mostly just read and learn. I need all new injectors for my 89 22re pickup. Would you please tell me where I cn purchase them on ebay if necessary?
Thanks,
Rick
Old 05-21-2014, 06:58 PM
  #58
FormerVendor
Thanks,
Rick
sent you a PM.
Old 05-23-2014, 05:15 AM
  #59
bam671's Avatar
flamethrower i sent you a pm posted here twice and you never responded at least message me with an answer geeez
Old 05-23-2014, 05:27 AM
  #60
vasinvictor's Avatar
He clearly gave a number to call and order if you are in such a hurry. No need to get jimmies ruffled over some free injectors. Can you imagine how many PMs he has to wade thru on every forum?
Quick Reply: 89-95 22RE/3VZE upgrade fuel injectors -free-
